Edited by ajaxauto, 29 April 2012 - 03:39 PM.
Husky 165 at the Viking National
Started by
ajaxauto
, Apr 29 2012 03:37 PM
10 replies to this topic
Posted 29 April 2012 - 03:37 PM
I ran a Walt Smith Husky 125 now a Husky 165 and boy did I have fun.Check out my first video.the poor little 165 was running with the open bikes and this old man finished 39 overall out of 247 who started
Posted 30 April 2012 - 08:34 AM
HuskyRips, on 30 April 2012 - 07:53 AM, said:
Norm is enjoying his 165 as well.
This is the bike Husky should build No need to retool and build a 200 As you can see in the Video the 165 can run with a open bikes in the open and pass the 300 2 strokes in the ruff. The motor is just perfect, you can lug it and it wil NEVER stall then just turn the throdel no cluch action needed and it will pull.As a over bore it will still rew if needed and scream in the open.Plus it is so light, perfect bike be in the woods or the desert I like it better then my Husky 300 now
Posted 30 April 2012 - 08:08 PM
Ajax is that a 2008 cr 125 now 165 and what carb are you running was it a 144 before. Did you need need to change jetting much from 144 to 165 I have my 125 cylinder still just sitting around. I could not believe how low that thing will lug my 2008 cr144 can lug a little but nothing like that. If I was riding my 144 in that terrain it would have to be on the pipe alot harder to make some of those hills,nice riding.
Posted 30 April 2012 - 08:36 PM
The truth is that is the stock carb as delivered from Husky .It was a 125 before we did the 165 .I did not touch the carb I just installed the 165 and it ran fine.Walt even rode it I have now rode the bike from sea level to about 4,000 no changes. It will lug .people will not beleive me until they watch the video.
Stock CR electronics 14 tooth front 52 rear still a 19 inch tire Make your bike a 165 install the fmf sx pipe and go have fun
Best part is 202 pounds and power to run in the open class
Posted 30 April 2012 - 08:52 PM
So it is a 2008 with tmx carb. When I went from 125 to 144 at about 80 hours I needed to lean out pilot and main one size and has ran great since from 2000 feet at home to 7000 feet at Moab Utah. I have about 150 hours off most mx use on bike so far and not sure if bottom end can take 165. Still running great but I am on 3 rd top end and have not touch bottom end yet. Thanks for help
Edited by pedec, 30 April 2012 - 08:53 PM.
Posted 01 May 2012 - 01:12 PM
The husky 125 bottom end is very robust. I have close to 100 hours of 165 time split between the old heavy Mahle piston and the new Wossner piston. Bottom end is still tight. I had ~80 hours of 144 use before that. I split the cases ~25 hours ago to install a true WR tranny and replaced the mains at that time just because I was in there. No need as the old ones were in virtually new condition(pulled them apart and no discernible wear). It also speaks volumes for Amsoil Dominator/Interceptor 2T oil mix. I wouldn't be afraid to put the new Wossner 165 kit on your bottom end. 1) Lower revs will actually extend life. 2) Very little weight difference between the two. Just make sure everything feels tight and smooth as silk when you pull it down. No rod end play and no notchyness in any of the bearings. No shaft end play at either end. I would be more worried about your main seals getting weak than the bearings and you can replace those without splitting the cases. JMO
Posted 04 May 2012 - 01:18 PM
I have had Walts 165 kit for a while, ran it a ton, compression stays up just fine. Same bike went to Moab with us as well as another 165 and tore off 200 miles of gnar in 104 heat... no problem, ran cool as a kitten. Great kit. Huge power over a 125. More like a 200.
This one has a FMF fatty for a KTM 200SX and runs real hard bottom to top on pump gas.
This one has a PC KTM200 pipe on it and is softer on the bottom and more on top which the owner prefers.
Posted 04 May 2012 - 01:36 PM
How is the camera mounted on your helmet? Some sort of soft mount or something? I can see the visor moving around with respect to the camera and the black sides of the screen were moving.
