Rekluse Core EXP 2.0 users...are your STARTS faster?
Posted 29 April 2012 - 12:04 PM
Do you feel you can go from zero to 30mph (like a start/race to turn one) faster with the rekluse, or, are you faster without it? Not whether you are more consistant, but overall, are you faster to turn one with or without the use of the Rekluse?
I know the Rekluse is an amazing product, and the tech help has been awesome!! But, my question is ONLY in regards to whether the bike (250cc four stroke) is faster to turn one with or without.
Thanks in advance,
Posted 30 April 2012 - 11:01 AM
Posted 30 April 2012 - 11:15 AM
But, it does take some technique, start in second and while the other guys are spinning up in 1st or backing off to keep the front down you just keep it pinned and when they change to secong you jump a bike length or more, its great!
Posted 30 April 2012 - 02:57 PM
mkeeping, on 30 April 2012 - 11:01 AM, said:
Just like you said........only if a body could rev the rpm's up a bit and not use the clutch. Thats the down fall to the Rekluse,You cant rev the bike while on the gate,thus not being able to get that quick jump off the gate to stay with every1 else.
if you r sitting on the line just at idle and the gate drops then u gas it,every1 else gets the jump on u cause they were reving there bikes and u weren't thus leaving u behind a bit. You could take off from the gate in 3rd at idle and if its a long start stretch then when everyone else in shifting into 3rd you r all ready in 3rd and will not have 2 shift and may pass a few or get 2 the front cause you didn't have 2 shift.
Posted 30 April 2012 - 03:02 PM
CaptainKnobby, on 30 April 2012 - 02:57 PM, said:
what? it takes 2 steps
step1 pull clutch
step2 rev motor
Posted 30 April 2012 - 04:43 PM
in reference to dead engine starts for harescrambles, The guys with 2-strokes have an advantage as the bike fires off very easily in gear. My good buddy in SrA with me has a 2010yz250. I suggested he get the exp2.0 after wrist surgery, big mistake (for me
There was a VERY good video by Jason Raines on his offroad viking video website, but i couldn't find it the last time i looked.. they have dead eng. starts in GNCC but sitting on the bike, he runs the bike, heats up the clutch a bit, then with the lever pulled in kills it. Looks for the right spot in the kick starter lever .. and fires it off with the clutch lever still pulled in as all the plates are apart i guess.
I heard Kenny Keylon (ssA super fast guy, former AA rider down here from years back) puts a stick in his barkbuster of his kx450 four stroke to hold the clutch lever in for his starts. he gets the hole shot most times and as i said, for whateever reason the kx 4t starts in gear reliably
MX? might be a different story.. good starters may get better starts feeding the clutch? If you rev the bike with the lever pulled in, the EXP 2.0 is engaged! the weights are spun out and you should be able to feed it like normal. Sure, taking off from a gate mx start at idle and just gassing it would not be the best way to go in my opinion.
Edited by MELK-MAN, 30 April 2012 - 04:49 PM.
Posted 01 May 2012 - 03:05 AM
MrBlahh, on 30 April 2012 - 03:02 PM, said:
step1 pull clutch
step2 rev motor
I know that!......I was talking about taking off from the gate at idle (no reving) clutch lever out. When gate drops........twist throttle .....and go!!!!!! by doing it this way......you cant beat the others off the gate......Due to the fact that your engine is not up into the RPM's thus making the launch from off the gate slow.
1 Step: Sit and wait for gate to drop
Posted 01 May 2012 - 11:17 AM
For hare scrambles I have the bike in gear and my crf450 starts reliably. The Rekluse has really improved my hare scramble starts.
Posted 01 May 2012 - 03:01 PM
no crap?? dang. no way will my crf450r start consistantly in gear.. what oil, what clutch plates, oem or aftermarekt basket?
Posted 02 May 2012 - 05:40 AM
cdaniels, on 01 May 2012 - 04:14 PM, said:
I havent heard one person say the Rekluse makes starts faster under the normal mx/flattrack type gate starts.
I was going back and forth about buying a rekluse for the trail... after riding a bike with one in...no chance in hell... it felt goofy and kind of took the fun out or riding. Maybe it was the way it was tuned, maybe not... either way not going to happen. I like clutching and being able to lug a bike at near idle with out having the engine disengage.
But i just wanted to point out that Rekluse doesn't advertise "faster starts" just more consistent ones!
Posted 02 May 2012 - 06:52 AM
mkeeping, on 02 May 2012 - 05:25 AM, said:
running the same engagement springs as they came from Rekluse? 3blue/3red?
I run the white jug rotella but used to run blue jug rotella on the clutch side, but found the synth rotella to not engage as hard, and the oil would come out dirty faster as the clutch was slipping more than it should .. i felt anyway.. talking with the rekluse techs, they suggested NOT using the synth but rather the white jug rotella and sure enough, after 15hrs and a few changes of oil, it is hooking up better and not gettin dirty AS fast.
Still can't start in gear all the time though
Posted 02 May 2012 - 07:00 AM
try riding your bike in some TIGHT single track for an hour, fast, with other guys breathing down your neck or bumping into them in front of you
That said.. and not turning this into a use vs. not use debate.. it was about does it improve starts, but most GNCC guys do NOT use autoclutch BUT you need to understand, those courses are 40' WIDE and much more open than harescrambles (that incorporate single track) and enduros.
Posted 02 May 2012 - 09:59 AM
