Will 2006 yz450 graphics fit an 07 wr450?
6 replies to this topic
  • huero
Posted April 28, 2012 - 09:22 PM
Man, I have spent the last half hour trying to answer question? Can anyone help? I have an 07 wr450 and would like to put yz graphics on it. I have replacement plastic kit from acerbis for the wr.
  • huero
Posted April 29, 2012 - 01:01 PM
I still haven't found the answer. In pictures, I can see some very small differences. But, they look so similiar, it's hard to know for sure. I just don't want to spend the money for the yz graphics and be sorry.
  • zibbit u2
Posted April 29, 2012 - 02:46 PM
should work so long as you use earlier generation aluminium framed YZ graphics. Only issue you might run into is the tank graphic because generally WR's run a larger tank.
  • huero
Posted April 29, 2012 - 04:42 PM
Thanks RS,
I appreciate you help.
  • zibbit u2
Posted April 29, 2012 - 04:46 PM
but why not just order a WR specific kit.. then you know it'll work.
  • huero
Posted April 29, 2012 - 06:28 PM
Good question,
I have a new acerbis wr450 plastic kit in white. So, I need white graphics. Or, rather, red white and black graphics. One industries makes a kit but, it's for the yz. So, that's the only reason is to get the color I would like.
  • Frostbite
Posted April 30, 2012 - 02:51 PM
I put YZ graphics on my 07 450. The front and rear fender graphics fit fine. The rad shroud graphics are a bit different, but I stretched them with a heat gun and trimmed a bit with a knife. I didn't install the side cover decals. I just installed a spare set of plastic that I had for my 07, onto my 2012. You can see the shroud graphics look OK.
Edited by Frostbite, April 30, 2012 - 02:52 PM.
