Reduce reuse recycle - 02 Mikuni TMX on a 98 CR250?
23 replies to this topic
  • shrubitup
Posted 28 April 2012 - 10:24 AM
Anybody ever done this? I imagine I would take my 02 intake boot and then bolt on the TMX carb to the 1998 cylinder.
This is not about performance. Just want to make run to sell.
With the to be vacated carb from my '02 it would get a '00 PWK. The nuances are great enough to switch - noticed this directly with my KX that has a clean running PWK. The TMX turns the CR250 into a woman. Very inconsistent responses. Sometimes perfect but oft something's amiss. Lean surge idle comes one day and gone the next even amongst the same air temp and elevation. :banghead:
My 98 CR250's Keihin PJ has seen one too many rebuilds itself whereas the TMX I'd put on it pretty mint. Right now gas flows out the overflow and I've put a new float and float valve in. No improvement. Earlier it would not run without choke on even with a new pilot jet.
Anybody ever bolted up a TMX to a '98 cylinder?
  • mynewcr250
Posted 28 April 2012 - 10:43 AM
fyi, there is an oring in the tmx that goes bad and causes fuel coming out of the overflow. its been about 2 years since we replaced it on my buddys 01, but i BELIEVE the oring sits in the brass "holder" that the nozzle/needle jet screws into. just something you can check so when you go to sell the 98, you dont have to explain to the guy how you put in a new float and valve and still have fuel coming out of the overflow.
but no, ive never slapped a tmx to a 98 cr.
  • shrubitup
Posted 28 April 2012 - 10:58 AM
I don't have this issue with a TMX - I have it with my Keihin PJ. Don't plan to sell a bike with a leaky carb hence idea of the swap. Thanks for note on O-ring though - if the TMX ever leaks I will look there.
  • mynewcr250
Posted 28 April 2012 - 11:10 AM
sorry, misread the post. what does the pj jet block look like compared to the pwk? this gasket, which if you believe what you read on the internet is "Unavailable" might be the source of your overflow. its the jet block gasket under the 2 tamper torx screws. the gasket is $3.70 plus shipping. even easier to try this than swapping carbs and boots just to sell the bike. but again, i dont have a PJ so im not sure what the block looks like compared to my pwk.
http://www.jetsrus.c...021_532_su.html
Edited by mynewcr250, 28 April 2012 - 11:18 AM.
  • shrubitup
Posted 28 April 2012 - 11:20 AM
I'm a go find what she looks like today. YES! This could make me very happy. :banghead:
  • mynewcr250
Posted 28 April 2012 - 11:22 AM
or very sad lol
  • ulmanb
Posted 28 April 2012 - 04:02 PM
thank you for posting this, I have been looking for a source of this gasket for months as I soaked a carb  in solvent during cleaning, not realizing this gasket was there, thus ruining it.
  • shrubitup
Posted 28 April 2012 - 05:03 PM
this is a gasket at bottom of PWK slide, correct? my PJ slide is different and doesn't have a gasket on it either.
  • mynewcr250
Posted 28 April 2012 - 05:43 PM
its not at the bottom the slide, its under the jet block, where the fuel supply runs through and the main jet attaches to. like i said though, not sure it applies to the PJ carb but figured its good to throw it out there.
edit: you bring up a good point though, if the PJ slide is different from the pwk then obviously this would be a lost cause. is your PJ slide oval or does it use a D shaped slide like the pwk does?
Edited by mynewcr250, 28 April 2012 - 05:49 PM.
  • hallsy
Posted 28 April 2012 - 06:50 PM
A word of caution here!!! Apparently the PWK jet block gasket that is available, is for the long body PWK's. The correct jet block gasket for the short body PWK's is similar but has a much smaller o-ring at position C than the long body gasket.This just came up the other day in the Jetting forum, take a look. http://www.thumperta...t-block-gasket/
  • shrubitup
Posted 28 April 2012 - 10:29 PM
PJ's slide is oval. You have brought up great points here regardless!
Edited by shrubitup, 28 April 2012 - 10:29 PM.
  • 2strokes4me
Posted 28 April 2012 - 11:06 PM
I think whoever is going to buy the bike, would probably prefer the leaky PJ to the mint TMX ... just sayin' .... I know I would. :banghead:
I'd spend the 90 bucks and put the proper carb on the bike before selling it, but that is just me.
  • MXHalofan
Posted 29 April 2012 - 05:52 AM
Got me thinking about my carb too. Got my new piston in last night and it's still takes a few kicks to start, acts weird, idles weird and leaks through the overflow with the slightest lean of the bike. Sounds like what you got Shrub.
  • shrubitup
Posted 29 April 2012 - 08:36 AM
2strokes4me, on 28 April 2012 - 11:06 PM, said:
I think whoever is going to buy the bike, would probably prefer the leaky PJ to the mint TMX ... just sayin' .... I know I would. :thumbsup:
Another 90 here another 90 there. I forecast to lose $300 on this bike anyway. Balance that with gains I've found elsewhere is what I keep telling myself. :banghead:
Yer float is too high. I bought another rebuild kit this time with new float. If no better then I will prolly just light this thing on fire. No, I spend mo money on it to make it right. So far I've:
  • put new tires/tubes on it
  • rebuilt top end
  • rebuilt forks
  • installed new rear disk rotor
  • new chain/sprocket
  • repacked silencer
  • rebuilt carb less new float :applause:
  • replaced all plastics
If I hadn't of found my KX I guess I'd be happy with it for a buddy bike.
  • mynewcr250
Posted 29 April 2012 - 02:38 PM
  • rebuilt top end
  • rebuilt forks
  • repacked silencer
  • rebuilt carb less new float :thumbsup:
youre on a kawi now? what'd you get? you get rid of your 02 cr? answers, now!
  • shrubitup
Posted 29 April 2012 - 03:02 PM
http://www.thumperta...kx250-for-1000/
Have all three bikes right now. That KX is sweet for woods torque!
  • mynewcr250
Posted 29 April 2012 - 04:50 PM
hows the power spread compared to the 02 honda? obviously better on the low end, but what about the rest?
  • shrubitup
Posted 29 April 2012 - 05:41 PM
Lacking from mid on up. Less snap. Plan to install wiseco pro-lite to help out. Corners very well even compared to the cr.
  • mynewcr250
Posted 29 April 2012 - 06:00 PM
ive heard that about the kx motors, not really my style of power, but for a dedicated trail bike or maybe if you ride tighter tracks id see it as good bike. honestly, for $1000 AND its an 04....its a good deal however you slice it. nice bike man.
  • shrubitup
Posted 29 April 2012 - 09:15 PM
Strictly a trail bike. Torque toque and more torque. Even sounds like a big bore. :banghead:
