07 YZ250f valve adjustment issues
Posted 27 April 2012 - 10:55 PM
2 of my intake valves and both of my exhaust valves were kinda tight.. about .001" too tight. Nothing major, but I want them to be back towards the middle of the spec range. When I measured the shims, the exhaust shims were .075" and the intake shims were a bit bigger, more like .080". Since I needed more clearance, I got some sandpaper and went to work sanding the .001" I need off every shim. I sanded for at least an hour and am missing a few fingernails and my fingers are down to nubs, but the shims didnt seem to measure much different.
Frustrated, I decided to just throw it back together and measure my clearances to see if anything changed. I decided to do this without the cam chain on, I was planning to put the exhaust/intake cams back in, and then put the chain on as thats how the manual instructs. Exhaust cam goes in, torque it down with my new cheapo harbor freight wrench, turns over smooth as glass by hand until the lobes hit the lifter buckets of course.
Then I go to try the intake cam.. torque it down (evenly as the manual suggests) and it turns by hand, but with quite a bit of resistance. Doesnt feel anywhere near the other side, and I dont feel like this is normal. Undo everything, clean it all, reinstall, do this about 3 more times to no avail. Tried a few different methods.. seating cam into cap first then installing, then tried seating cam into head first, then fitting cap.. no change. Even with the bolts finger tight, it still doesnt turn great.
What is going on here? I did notice when installing it, I feel like one (or more) of the valves is being compressed a little bit, but why would this happen and what could cause it? Could my shims I "made" cause it? First thing Im trying is going to a dealer and buying new shims (correct way) and lightly sanding the journals with 2000 grit sandpaper. Any other suggestions??
Posted 28 April 2012 - 05:12 AM
You don't sand down shims, you just don't do it. pack up the bike and parts and go drop it off at a shop and let them put it back together.. I'm not looking to be a bitch but it's easy to see your over your head with this one..
Posted 28 April 2012 - 07:18 AM
I am no where near over my head. I have all the tools needed for this.. micrometers, torque wrenches, flywheel puller, etc. I got the chain swapped out in 15 minutes or so, but this is my first time doing valves.
I got that advice to sand down the shims on another forum. I am not going to name the forum. I will go buy some various shims and put it back together. Hopefully that is the problem.
Posted 28 April 2012 - 07:59 AM
BTW...you can remove a small amount of material from a shim. Remember they are case hardened, so anything more will render them useless.
Posted 28 April 2012 - 08:52 AM
Posted 28 April 2012 - 12:04 PM
Posted 28 April 2012 - 12:52 PM
The net has a lot of good info and a lot of people that know what they are talking about but t the same time it is also filled with shit. You said you have the service manual go by that and if they tell you to replace something it's a good bet they know what they are talking about.. Sanding shims, drilling jets, cutting wires will never save you time or money.. I will stay away from that site that told you to sand them down, TT is a good place for reall info and if someone gives you a load of BS someone will see it and call them on it so it's a safe place for help...
Do what Swede said replace the shims you sanded down and start over..
Sorry if I came off hard, I hope you get it back together and running real soon..
Posted 28 April 2012 - 05:26 PM
Posted 28 April 2012 - 09:35 PM
Posted 28 April 2012 - 11:39 PM
I had to take the cams on and off about 5 times and keep swapping out shims, but eventually I got it. The intakes are all around .005" tolerance, and the exhaust is .008" I believe. Not 100% sure if I am remembering those numbers correctly, but everything is in spec.
Also took me 2 trys to get the cam chain on correctly.. what a PITA that is. You need like 6 hands to do it, I had to have a friend help me. I think I got it. The marks all line up when Im at TDC, but the only questionable thing.. Im not sure if I am on the right stroke. I know I am supposed to be on the compression stroke with the marks line up at TDC. When my marks DO line up at TDC, when I push the kickstarter down I immediately feel resistance. This would be the compression stroke right?? I sure hope so, cause its all back together and Im going to hopefully start it up tomorrow morning
Posted 29 April 2012 - 07:15 AM
Posted 29 April 2012 - 08:42 AM
If it doesn't start, after your work, pull the pistion and sand the rings...JK
Posted 29 April 2012 - 09:35 AM
Posted 29 April 2012 - 09:40 AM
When I went to the dealer they wanted something ridiculous like 8 bucks a piece for an OEM shim
I was also scratching my head over tight cams not wanting to rotate when I first installed them with my new valves. Turns out there was no clearance with the oversized shims installed. It could have been that one or more of your shims weren't seated correctly so it was making it seem taller.
The stroke is determined by the cams so as long as you are at TDC (it's all the same with the cams off!) and you aligned the cams correctly according to the manual, then you should be good to go! I too was really struggling with getting the cam chain on and the cams timed properly... maybe there is some secret technique?
Posted 29 April 2012 - 02:19 PM
Do yzf models have issues with this? Is it best just to replace the valves if there is build up or if the shim(s) height needs to be lessenend. Does a compression check / leak down check tell anything about valves or only whether the rings are good? The manual is a good source for how to, but doesn't really give me a feel for how often replacment maintenance is likely to be needed.
Thanks in advance for any tips. I just want to treat my bike right and keep it reliable and become self sufficient.
Eric
Hudson, Fl
Posted 29 April 2012 - 03:00 PM
Depending on your level of riding and maintenance routine you should be able to get 50 to 100 hrs on the valves.
Hard starting when the bike is cold is a good indication that the valves are getting tight. This being the case with a properly jetted carb.
Posted 29 April 2012 - 03:01 PM
Posted 30 April 2012 - 07:28 AM
On a related question, what to the valve seats look like if they need to be cut?
My bike is especially hard to start sometimes when its hot. I do not have the hot start lever, so apparently it was removed. I think my bike starting challenges when cold speak more to my poor technique than valve or carb issues. Normally, it starts in three kicks. It seems sometimes I flood it, though.
Posted 30 April 2012 - 07:38 AM
It runs great. Hot starts great, but it didnt seem to like cold starting with the choke on. Choke off it starts up. I may try it again today to make sure. Also, there seems to be a lot of mechanical noise coming from the cylinder head.. and Im not sure how much noise is normal. I noticed this with my helmet off, so maybe I am going crazy. I think I might pull the head and check the clearances and the timing marks again just to make sure Im not.
