Mystery Jet on FCR39MX
4 replies to this topic
  • snowdave
Posted April 21, 2012 - 06:17 AM
I finally have my 2003 YZ450F rebuilt after buying it with a broken case this winter. It runs pretty poorly and I quickly realized I had reassembled the carb incorrectly. This was the first FCR carb I have ever worked on. I had put a type of mystery jet in the Main Air Jet hole since I could not find any other spot it could possibly go. Naturally this kept the main from working at all. My big question is what the heck is this jet/part and where does it go. It is about 1/2" long with no threads, but a screwdriver slot in the top and a very small hole running through the middle, but exiting out the side, not the end.
Sorry for the horrible pic, but my camera cannot focus super-close. I will try again later if you need a better picture to help.
  • bcollins82
Posted April 21, 2012 - 10:55 AM
By guessing from the pic it looks like the accelerator pump nozzle.... Does it have a small hole only in one side?
  • snowdave
Posted April 21, 2012 - 11:25 AM
Yep, a small hole pointing to the side. Here is a better pic:
  • snowdave
Posted April 21, 2012 - 12:52 PM
Indeed it was the accelerator pump nozzle. Thanks so much for the help. This is the first carb I have ever worked on that has a secret, "DO NOT DISASSEMBLE", portion. The bike is running much better now so I can get onto regular tuning.
Thanks again.
Posted April 21, 2012 - 02:51 PM
Thanks again.
I imagine it would run rather poorly with that shoved in the main air jet intake. :thumbsup:
Your carb also has a non-serviceable float needle seat, as I recall (the needle IS serviced). They started that in '03 or '04 at the latest. Don't try to remove it.
  • 5 replies
  • Hot  47 replies
  • Hot  28 replies
  • Hot  36 replies
