My buddies younger brother has a Raptor 350 Quad and the rear axle bearings have gone bad. Are there any tricks to getting the main axle nut to break loose? The two set screws are already all the way out and on the table, but this thing is locked up solid. Is it a standard right hand thread, counter-clockwise to loosen? Are there any specialty tools that may be "Impact Gun" driven? (Who knows, an offset wrench or socket?) Tips and tricks are welcomed.
Bustin a nut, Axle nut that is ... Raptor 350 ...
Started by
Pezman04wrx
, Apr 21 2012 02:53 AM
1 reply to this topic
Posted 21 April 2012 - 01:42 PM
This thread can be closed out ...
Notes:
Notes:
- The axle nut is definately RH Thread (Counter-Clockwise to loosen) ...
- They do sell a specialty 46mm offset open end wrench ...
- However, you can also use a 4ft pipe wrench ...
- Map gas is your friend, use liberally ...
- Removing the bearings, or whats left of them, is even more fun ...
Yamaha
2002 warrior 350ATV/UTV → Make/Model Specific → Sport ATV |
Yamaha
'01 Big Bear rear oil leak & a question or two.........ATV/UTV → Make/Model Specific → Utility ATV |
Yamaha
87 Yamaha Warrior YFM, Igntion Sparks when Ignition Off, No Spake when ONATV/UTV → Make/Model Specific → Sport ATV |
Yamaha
yamaha blaster wont runATV/UTV → Make/Model Specific → Sport ATV |
Yamaha
600 Grizzly no sparkATV/UTV → Make/Model Specific → Utility ATV |
