Questions while doing my first top end
Posted 19 April 2012 - 01:48 PM
Posted 19 April 2012 - 08:19 PM
I just cleaned the head up with gas and compressed air since I was replacing the valve stem seals anyway. I'm not sure what cleaners are safe with the head; but gas hasn't seemed to hurt or discolor it in any way.
Posted 19 April 2012 - 08:21 PM
Posted 20 April 2012 - 04:43 AM
Posted 20 April 2012 - 07:26 AM
Posted 20 April 2012 - 09:16 AM
Posted 20 April 2012 - 07:24 PM
Posted 21 April 2012 - 01:56 PM
Posted 21 April 2012 - 03:05 PM
mjbd, on 21 April 2012 - 01:56 PM, said:
Is the piston attached to the crank yet, or are you trying to put it in the barrel while the piston is off the crank rod? Believe it or not, there is enough clearance to attach the piston after it is already in the barrel (just enough). Some find it easier if they don't have a ring compressor to put the piston in the barrel before attaching the assembly to the crank. It allows you to see ring binding problems easier and stop before folding the oil ring and wiper over too far and damaging them. If your piston is attached to the crank and you remove the cir-clips to try the alternate method, be advised that you should replace the cir-clips with new ones even though they haven't been run in. They are one of those type of cir-clips that you compress once and once only to insert in the cir-clip cavity.
My friend kept missing putting the cir-clip in the slot too many times and he compressed the clip once too many and he had a cir-clip failure. Just giving a heads up on that one. Many will dispute how you place the open ends of the cir-clips that hold the piston pin in place (6 o'clock position or 12 o'clock position - but if you look carefully in the manual, there is no doubt how the engineers want you to place those cir-clips (open end facing down/6 o'clock position) that are going to be flying up and down at 10 grand + revolutions per minute.
Edited by nokickstandsallowed, 21 April 2012 - 03:38 PM.
Posted 22 April 2012 - 05:28 AM
Posted 22 April 2012 - 07:39 PM
mjbd, on 22 April 2012 - 05:28 AM, said:
This is another reason why I stick with eom pistons on a stock bore cylinder.
Posted 23 April 2012 - 03:23 PM
Posted 23 April 2012 - 04:13 PM
Posted 23 April 2012 - 06:15 PM
mjbd, on 23 April 2012 - 03:23 PM, said:
You dont need to use the exact stuff the book says. Make sure you clean the threads on the bolts and the holes they are going into. Then just dip the bolt threads in the oil you are going to run in the bike. All you are doing is lubricating the threads so that when you torque the bolts down you get an accurate torque on them. Its really that simple.
Posted 24 April 2012 - 04:15 AM
Posted 24 April 2012 - 04:03 PM
mjbd, on 24 April 2012 - 04:15 AM, said:
Wait, your head bolts are speaking? I wish all my parts said something, so I wouldn't have to read the damn manual.
Relax, I'm J/K - I know what you meant
The reason the manual suggest a grease lubricant, is because oil on the threads will drip down into the hole cavities of each bolt hole and eventually on a fourth or fifth rebuild (if using oil each rebuild) of the top end, you will experience oil wedge lock (if you don't flush the oil out) and it will fool your torque wrench into believing it has acquired the appropriate torque value because it cannot compress the oil down in the holes past the threads fast enough to compensate for what would be assumed to be the correct torque on the first tightening sequence.
The bolts, as you are probably aware, need tightened in a sequential staging pattern until the proper torque is achieved on each bolt. If you forgo doing sequential tightening, you will warp or damage your head and or cylinder in the process. With excess oil down in those holes, reaching an accurate sequential tightening pattern torque becomes difficult or incorrectly achieved if oil wedge lock occurs.
Charlie755 is pointing out a very important step, if you use oil instead of grease; and that is to thoroughly flush the deep well bolt holes out (because they are sealed on the bottom) and make sure the threads are clean on both the bolts and holes. This step should have been done long before putting the cylinder and head on, because it is easier to see how much is down in those holes; but, not impossible to still clean them out if any oil or grime is down in them.
I used Lucas ® grease myself for the application. The green or red flavors work just fine, even though I have used oil (the type I run in the motor) to lubricate them on the first two top end rebuilds I did before letting someone else try there hand at fixing my bike. But that is another story documented in a rebuild thread I shared last year on TT.
As far as your never seize question, I have no advice, as I have never used the stuff in a head bolt application on these bikes.
Edited by nokickstandsallowed, 24 April 2012 - 04:30 PM.
Posted 24 April 2012 - 04:43 PM
Posted 24 April 2012 - 05:02 PM
mjbd, on 24 April 2012 - 04:43 PM, said:
Your Welcome, fellow Buckeye rider.
I miss the Heart of it All
I miss riding in the slag dumps and quarries. Now that I have a 250F, there are a few hills that use to beat the snot out of my less powerful bikes that I want to go back up their <<<oops, I meant there - and give a try now that I have a capable machine that can climb the longer hills. The hills were so long, that my smaller bikes just didn't have a wide enough ratio in the gearing to keep climbing them, and they would bog down half way up the suckers.
Edited by nokickstandsallowed, 24 April 2012 - 05:09 PM.
Posted 25 April 2012 - 06:40 PM
Excellent post man.
Edited by Charlie755, 25 April 2012 - 06:41 PM.
Posted 25 April 2012 - 09:41 PM
Charlie755, on 25 April 2012 - 06:40 PM, said:
Thank You.
I think the reason I go into such detail, is not to over explain something (even though I do
I'm glad you realize that I wasn't talking down to him, and I even got lucky by pointing out something just because of your post, and I think mjbd understood I was just going into depth so that I could share mistakes I came across, so that hopefully he can avoid similiar ones.
Two eyes, two ears, and one mouth - but I have eight fingers and two thumbs that won't shut up
Thanks again!
