SWAAAAMMPED :(
8 replies to this topic
  • BrandonPley
Posted 19 April 2012 - 10:56 AM
got to the riding spot yesterday, waited half an hour for the other guys to show up, rode for about 20 mins, then hit a puddle so big the bike was up to the bars under water :thumbsup:
i got a pick of me pushing it out.. i tried to get out as fast as i could before they caught me under water lol.
it was a sad day for me...
  • BrandonPley
Posted 19 April 2012 - 10:59 AM
  • 230Fstroker
Posted 19 April 2012 - 11:47 AM
:thumbsup: whoa..
  • BrandonPley
Posted 19 April 2012 - 12:23 PM
i know.. what a shitty day
  • 230Fstroker
Posted 19 April 2012 - 01:35 PM
Nothing like taking a bath when you don't want to. Did you get it shut down in time to save it?
  • BrandonPley
Posted 19 April 2012 - 02:00 PM
barely.. still wouldnt run for shit after..
drained the airbox, dried the filter, drained the carb, it would start, but wouldnt run well..
towed it around behind a quad and left it in 2nd gear till she popped and ran ok.. bogged out before it hit the rev limiter..
CMON SCREWED UP PISTON!! i wanna BBK! lol
but i gotta drop all fluids and clean and inspect tonight.. i will update when i see more :S
Edited by Marauder01, 19 April 2012 - 02:02 PM.
  • BrandonPley
Posted 19 April 2012 - 07:17 PM
Well! got 'er unloaded
drained oil
removed fuel tank
bled the carb
emptied fuel tank
removed air box cover and air filter
cleaned air box
cleaned air filter and reinstall
refill oil after cleaning oil trap screen
put the tank bank on
filled 'er up
changed spark plug.. fouled to all hell?? maybe from water??? the thing is COMPLETE BLACKNESS...
install new spark plug (cuz i was smart enough to buy one while at the honda store :thumbsup:)
drill out broken battery box bolt, easy out the stupid thing :thumbsup:
reinstall battery box cover
install seat
twist throttle
fired up, runs like a hot damn..
may have jetting issues.. i wonder if the water would have fouled the plug?
  • Toast
Posted 20 April 2012 - 07:30 PM
here's something to add to your list.
"with plug out push start button until no water or vapor come out.  Sprayed WD 40 into cylinder and leaned on the starter again"  WD means water displacer
"cleaned vent hoses"
If your oil looked like coffee with creamer than change it after your next ride.
We had one go under while running.  Had water in it from Air box to tail pipe.  Got it running again though.
It had water in crankcase so changed oil.  Ran it 15 minutes.  changed oil again.  Took it on 3 hr ride, changed oil again.  Now on regular interval.
Good luck!
  • BrandonPley
Posted 20 April 2012 - 08:13 PM
Mmm, did the wd40 with the plug out while we were on the trail, didnt bother again..
And no, the oil looked like used oil.. no water in the bottom end:P
