XR250 fork changes
3 replies to this topic
  • 102dals
Posted 15 April 2012 - 12:45 PM
What forks work in an XR250 setup? Anyone tried replacement with XR400s? If so, what else needs to me changed, ie: wheel/rotor/triples, etc? I assume triples at a minimum, but do the forks need spring/shim/damper mods?
Thanks in advance, Andy (a TT newbie)
  • Baja trail Rider
Posted 16 April 2012 - 06:21 AM
The xr4 forks can be made to work great.triple clamps,xr4 compleat front wheel,axle.Or your xr250 wheel with all xr4 spacers,speedo drive,seals,bearings,axel.stock forks work good ,but shim mod,.43 springs,2 -1/2 oil work better.
  • Enc_1
Posted 16 April 2012 - 07:22 AM
Xr400 forks drop right in, plug and play.  I did this mod and am very happy with it, huge improvment.  I found forks, clamps and wheel for $200 on Craigslist.  You can reuse XR250 brakes and wheel, but you'll have to change the wheel bearings to accept the XR400 axle and the spacers,speedo drive,seals too.  I think this is the easiest, cheapest upgrade one can do to the XR250 suspension.  However, to get the most out of this upgrade you will need to spring them for your weight and do the shim stack mod (remove 6 shims from the compression stack).
Edited by Enc_1, 16 April 2012 - 08:56 AM.
  • michigan400
Posted 16 April 2012 - 10:23 AM
Entire XR400 front end for sale on ebay for 150 clams. Triples, forks, front wheel (good luck finding a front wheel for 150!!) handlebars and fender. Get it while you can. (FYI - It's not mine, just seen it looking through the parts for sale )
Edited by michigan400, 16 April 2012 - 10:24 AM.
