clutch perch question
22 replies to this topic
  • Evil_CR
Posted 14 April 2012 - 07:19 PM
i recently picked up a 06 yz250, the clutch lever had alot of play in it, i thought it was the cable so i orderd a new thinking it was stretched, side by side new and old are the same length, i have the cable adjusted all the way out and still lots of slack. Now the bike came with asv levers, could the clutch perch be from another bike not designed for the yz and this is why its giving me problems ?
  • RCannon
Posted 14 April 2012 - 07:43 PM
I think so.  Most aftermarket perch's use Hond aleverage ratios and cable pull specs. These dotn match Yamaha well at all.
  • Evil_CR
Posted 14 April 2012 - 08:16 PM
you think the clutch could be hung up if the basket is notched and not letting it return all the way out? i'll look in the morning to see if the clutch basket is notch.
  • RCannon
Posted 15 April 2012 - 05:11 AM
A basket woudl need to be seriously notched to do this. Probably unrideable if it were that bad.
  • Evil_CR
Posted 15 April 2012 - 05:28 AM
alrighty thank you , by any chance can anyone take a pic of their clutch lever (yz250) behind the flywheel cover so i can see the position of it to see if it looks like mine
  • arnego2
Posted 15 April 2012 - 05:37 AM
Its a 9 o'clock or 3 o'clock position depending from which side you look at it. Points straight at you when sitting in front of it.
  • Rodneya
Posted 15 April 2012 - 07:02 AM
There should be 2 places to adjust the cable. One at the perch and one on the cable. I have seen a lot of people overlook the one on the cable before
  • kan3
Posted 15 April 2012 - 10:43 AM
Maybe I can tack a question I had on here as well.  My 05 yz125 came with asv clutch/perch installed and oem spare.  I wanted to try the oem as the asv doesn't seem to have good modulation to it.  I can feed slack in or out on the clutch but the 0-100% engagement on the clutch is a very small portion of the lever stroke.
So, I put the oem on and it seems the clutch cable isn't long enough.  I have the adjustor on the perch and on the cable turned in all the way to get as much slack as possible.  I can only manage a little over 1/8" of free play at the clutch.  This is giving an even smaller window of modulation than the asv because disengagement is right at the start of the lever pull allowing no modulation.  This is a brand new oem clutch cable so it seems strage.  I checked the old one I pulled out and it's the same length.
Edited by kan3, 15 April 2012 - 10:44 AM.
  • RCannon
Posted 15 April 2012 - 01:50 PM
If the bike has had aftermarket plates added, all bets are off.  Some of these are thinner, or thicker, and th ematerial is not as good as oem. If your chasing clutch problems get the oem plates first. It will save a lot of issues later.
  • Evil_CR
Posted 15 April 2012 - 04:05 PM
i believe the clutch is stock, look at basket thru the oil fill today it has little notches nothing big, but got the cable all extended out and the perch and it just enough slack so im pretty sure its the pos perch, what do you guys suggest for another brand perch thats compatible with the yz ?
  • Evil_CR
Posted 17 April 2012 - 04:57 AM
What do you guys recommend for brand for a clutch perch that fits the yz pull?
  • MxSkater86
Posted 17 April 2012 - 07:54 AM
You should look into this first. Did you use the adjuster on the cable also? I use the stock perch from the newer YZ's because I think there just as good as any aftermarket perch at half the cost.
  • MaddogYZ
Posted 17 April 2012 - 08:09 AM
I just bought an 09 YZ250 and I'm replacing the clutch perch to get an easier smoother pull, I've been spoiled by a hydraulic clutch. I got the Streamline perch and lever assembly from Rocky Mountain and I'm actually returning it after one ride with it. The perch is great, very good build quality, good fit, nice ball bearings, smooth pull...but the lever shape is horrible. There is no radius contour to the lever, its very flat where your fingers wrap around lever giving it an uncomfortable and bulky feel, it puts preassure points on your fingers that tire your hands quickly. I'm returning it for a Pro-Taper (elite?) ball bearing perch, it doesn't have a folding lever but I have wrap around handguards so I don't really need one.
  • kan3
Posted 17 April 2012 - 08:48 AM
If you liked the hydro why not just buy one?  The magura or streamline rebrand are $100 more but at least you know you WILL like and be happy with it.
  • MaddogYZ
Posted 22 April 2012 - 05:12 PM
So I got the Pro Taper Profile clutch perch in and any improvent over the stock pull is marginal, there really is no replacement for a hydro clutch. I'm not going to send it back, I'll ride with it a couple times and I'll probably just get used to the heavier pull than my Husaberg that I had.
  • Evil_CR
Posted 22 April 2012 - 05:42 PM
i was looking at the pro taper set up and waiting for people input on it haha ,i got a chance for a great deal on works connection set up, should i jump on it? how is the pull on the WC?
  • TAG Racing
Posted 23 April 2012 - 04:56 AM
i have the MSR lever and perch, its awesome. Great smooth pull and under 30 bucks for the whole set up
  • MaddogYZ
Posted 23 April 2012 - 06:37 AM
I had a mental block on the MSR perch, it seemed to cheap for it to be any good :banghead:
  • TAG Racing
Posted 23 April 2012 - 06:55 AM
its soo nice. huge on the fly adjuster that clicks right into position every time.
  • Evil_CR
Posted 23 April 2012 - 09:52 AM
If I can get the WC setup for near the price of the msr should I jump on that deal?
