carb function question
Posted 14 April 2012 - 08:09 AM
Posted 14 April 2012 - 09:24 AM
fgrote, on 14 April 2012 - 08:09 AM, said:
http://www.sudco.com/
Sudco P/N 021-726
Keihin P/N 1099-817-6000
Seal, Release Plate
Posted 14 April 2012 - 11:18 AM
Posted 14 April 2012 - 02:33 PM
Edited by mrmoto35, 14 April 2012 - 02:33 PM.
Posted 14 April 2012 - 04:03 PM
mrmoto35, on 14 April 2012 - 02:33 PM, said:
my metal plate has some wear on it , so im scared to just buy the seal , and waist more money. when i went threw my carb i put some grease between the two ,thats probably not a good thing ,it might keep the plate stuck to the slide.?
Posted 14 April 2012 - 04:12 PM
Posted 14 April 2012 - 04:24 PM
Posted 14 April 2012 - 04:33 PM
Posted 14 April 2012 - 04:47 PM
http://www.hbhonda.c...2008&fveh=20243
Posted 14 April 2012 - 05:53 PM
The wear i have ,is only on the bottom of the plate on both outside edges another thing that bothers me , is the plate is metal , the carb body its rubbing agaist is aluminum , if the plate has uneven wear , its pretty obvious the body of the carb has uneven wear too
Edited by fgrote, 14 April 2012 - 05:59 PM.
Posted 14 April 2012 - 06:03 PM
Posted 14 April 2012 - 06:34 PM
Whats the issue you are having, what are the symptoms?
Posted 14 April 2012 - 07:05 PM
Posted 15 April 2012 - 06:53 AM
so calling it a seal plate isnt a good word for it ,honda calls it a floating valve , it really actuates ,so in oder for it to do that you really dont want to have anygrease there as i did , that would impair it from actuating , and even if the rubber looks good it could flatten and need replaced ?
Edited by fgrote, 15 April 2012 - 07:10 AM.
Posted 15 April 2012 - 09:44 PM
