Fuel injected 2 stroke Not DI ?
Posted 13 April 2012 - 07:45 PM
Obviously im only scratching the top of a fairly indepth topic and if it were just a case of bolting on a throttle body then im sure manufactures would have done it some time ago
Posted 14 April 2012 - 02:40 PM
Posted 02 December 2012 - 11:08 AM
Posted 02 December 2012 - 11:46 AM
Somewhere I read about a nut that put mechanical fuel injection on a yz250. As in hillborne. I thought that was some bad azz sheet.
He said it worked better than the carb.
Now run some methanol through there ..... With a Verry high comp piston and head.
Will make 450s look limp wristed. Lol.
Posted 02 December 2012 - 07:07 PM
There are no problems with pumping premix through a FI system.
Fi can be set up to run WAY better that carbs, across all temps pipe or otherwise. Heck you could even add another 0-5v sensor to compensate for chamber temp.
If people actually bought two-strokes, they already would be advanced FI systems on them. I just bought a new two-stroke, but you probably didn't. Consumers are driving FI technology.
Posted 03 December 2012 - 06:49 PM
Posted 04 December 2012 - 08:34 PM
r_jackson, on 02 December 2012 - 07:12 PM, said:
Neat.
How about the ossa?
http://twostrokemoto...ture-of-enduro/
Posted 23 December 2012 - 08:05 PM
I don't know how much of the CRF's code can be tweaked in order to run a 2T and do it well. In my own research on the topic of adapting OEM systems to applications they weren't designed for, I concluded that it was necessary to have a lot of internal control over what the ECU does and how. I also concluded that "universal" aftermarket standalones make the whole thing a lot easier.
I thought that was a member here on TT, actually.
36MotoMarc, on 02 December 2012 - 07:07 PM, said:
2.) Fi can be set up to run WAY better that carbs, across all temps pipe or otherwise. Heck you could even add another 0-5v sensor to compensate for chamber temp.
1.) I think the primary industry motivation for using DI was probably to clean up emissions, not necessarily to increase output at the same time. Manufacturers peddle it to the public by touting the
2.) I agree.
Posted 24 December 2012 - 01:51 PM
...ktm and yam rumours
they developing it
...but another shop know of
FI'd a kart 125, and got
57 hp, sensors not aligned,
and jetting way off.
...will keep posting as development,
and results come in, but this company
has found bullet proof parts, and tech
from around the world, ... and are
projecting 60 to 70 hp from a 125
...call bs now, if ya dont believe it,
...but all the results will be posted,
positive, and more importantly,
negative.
...got nothin to prove, but the end
result ...and somebody that can
hang on to it !!!
Posted 24 December 2012 - 02:10 PM
Posted 24 December 2012 - 02:40 PM
they developing it
negative.
hang on to it !!!
I don't doubt the high numbers, its the reliability that I always doubt.....
Posted 25 December 2012 - 12:40 AM
very high quality con rods, ...have'nt seen
one fail yet, running 50 to 56 hp @
16,000 rpm on methanol, on a 150cc
High rpm injectors are probably the
hardest part of injecting a 2 stroke
Heard a rumour years ago, that Aprilia
developed a fuel injection system
for their 125, 250cc GP bikes,
probably using Magneti Marelli
system's, ...but the power was too
violent for the riders to handle /
would light up the tire too easy
coming out of corners.
Those 125's are supposed to have
about 58hp, ...and the 250's
( twin 125 cylinders ) were said to
have about 108 rwhp, with carbs.
Edited by yamaha7442, 25 December 2012 - 12:41 AM.
Posted 26 December 2012 - 12:17 PM
Perhaps with DI, but not so much with more conventional injector placement. The issue is getting enough fuel injected in the time between cycles and at an acceptable duty cycle. Injectors that do that at peak power often have poor low-load manners because the commanded pulsewidth drops into the injector's lower nonlinear range. There are simple ways around this using common automotive injectors, such as staged injection and overlapping injection events between multiple injectors.
Posted 26 December 2012 - 05:44 PM
Just trying to organize how to post photos?
This is an EFI twostroke. Crank case injectors, runs on ethanol / petrol, E90.
Uses a Link computer and a Ignitec Ignition. Goes quite well.
