WR/YZ cam swap
9 replies to this topic
  • andre661
Posted April 13, 2012 - 07:22 PM
Please help....lol. I have an 05 wr450 and I have been reading about this exhaust cam swap by installing a yz exhaust cam. I have also been reading about just changing the exhaust cam timing on the stock wr cam to basically achieve the same results. Which of these would work best and has anyone tried this before????
  • MANIAC998
Posted April 14, 2012 - 04:55 AM
You can do a search on this, as there is lots of good information out there on this subject. Using the YZ cam makes the electric start almost un-usable, as the engine will have too much compression for the starter to over-come. Maniac
  • Mbirt
Posted April 14, 2012 - 10:25 AM
Here's an excellent post on the topic: http://www.thumperta...ween-wr-and-yz/
I had to remove 1mm of length from the decompression pin on a 2011 WR exhaust camshaft when retarding it a tooth to get cold cranking compression back to its original level. The motor would not e-start at 10 psi before removing 1mm from the pin.
  • redhotz28
Posted June 28, 2013 - 02:41 PM
Hey guys- hate to butt in but didn't want to start a whole new thread. I just picked up a used 07 WR450, and when I went to check the valves I saw this. It runs fine, so I was wondering if the previous owner possibly retarded the stock WR camshaft one tooth instead of buying a new camshaft. What do you guys think?
  • KennyMc
Posted June 28, 2013 - 05:07 PM
Does the e-start work fine?
  • beezer
Posted June 29, 2013 - 05:07 AM
You may have a worn cam chain. Depends on how much time is on the bike.
  • redhotz28
Posted June 29, 2013 - 08:58 AM
The e-start works just fine. It takes 2-3 seconds to fire up, but it works every time. The bike is fairly new- person before me said <1000miles. I can't figure out how to check using the stock speedo unit and I didn't get a manual with it.
  • KennyMc
Posted June 29, 2013 - 04:17 PM
Here is a link to get the manual in a PDF format for free
http://www.thumperta...formance-index/
  • redhotz28
Posted June 29, 2013 - 04:37 PM
Thanks- I have that but didn't figure it would cover as basic an operation as using the speedo. Doesn't look like you can check total hrs/miles. Bummer! Wanted to get a vapor anyhow.
  • KennyMc
Posted June 30, 2013 - 07:55 AM
Oh, no, you are correct. They come with a resettable ODO so you will never be sure. When I just did my top end, I installed an hour meter.
