3 questions
2 replies to this topic
  • gal
Posted September 01, 2001 - 09:06 PM
1 can i take off the mid valve if i ride only enduro n off road - not moto? what does the mid valve do?
2 i saw in the former topics that i can replace 3 parts from the 2000 yz 426 to the 2001 parts - can i use the wr426 2001 parts instead ( thats what i can find in stock at my dealer shop)?
3 after every ride , specialy when i ride hard , i can see a few drops of oil from the over flow hose. is it something wrong or is it normal , how can i check/fix it if its wrong? ( i checked the oil level n i have 50-100 cc more then max)
  • PK
Posted September 01, 2001 - 01:17 PM
When you get a kit from Race Tech to revalve your forks, it eliminates the mid valve so I would you can eliminate it without problems if you have the knowledge.
What 3 parts are you talking about to interchange with a 2001 from a 2000?
The oil from the black breather hose is normal as long as it is only a few drips. If your oil is over serviced you will see a little bit more than usual, otherwise nothing to worry about.
Good luck,
Pat
  • mor
Posted September 04, 2001 - 04:26 AM
i read somewhere that if u change the 2000 parts to the 2001 folowing parts - friction plate,clutch boss spring and the seat plate of the yz426 the clutch will work better....
i was wondering if the 2001 wr parts and the 2001 yz parts are the same and if i can put the wr426 parts in my yz426 2000?
  • Hot  50 replies
  • Hot  30 replies
  • Hot  47 replies
  • Hot  38 replies
  • 5 replies
