Linkage Data CRf 450 2012
5 replies to this topic
  • racerfmx450
Posted 13 April 2012 - 12:56 PM
I would like to put my Öhlins Shock HO1094 in my new CRF 450 2012.
unfortunately the linkage is different so i compared the linkage of the 2009 and 2012 CRF side by side, just to see what is different.
But I can do not see any difference ! nothing,absolutely identical..
also the swingarm, same lenght , same bracket for the Linkage..
the shock has 493mm (1mm shorter ) and  5mm more stroke.
ps: The Öhlins shock fits perfectly, i have 494mm and 127mm stroke at 10000N.
So what about the magical 2012 Linkage!
  • mog
Posted 13 April 2012 - 01:21 PM
If it starts and ends at a different place I guess they can claim its diffrerent?
  • englertracing
Posted 15 April 2012 - 10:05 PM
Did you measure the link with a caliper.
  • kawamaha
Posted 16 April 2012 - 10:21 AM
it's also possible they relocated the pivot at the frame...
  • racerfmx450
Posted 16 April 2012 - 11:46 AM
i have compared the linkage side by side,
no different  larger  as 0.1mm
  • racerfmx450
Posted 16 April 2012 - 11:53 AM
the swingarm and frame looks the same, but i cant messure the monting points exactly at time.
i hope next week with a laser.
and the fork its 3mm longer then 2009.
the outer tube its stiffer (thicker) on the upper part
and the forksprings are 0.1 N/m stiffer
(2009 .46 KG/mm=.47 N/mm 2012 .48N/mm)
