fcr car question
Posted 12 April 2012 - 11:30 PM
i bought my first DRZ a few days ago 04 yellow s model . mods are 434 big bore, e cams,yosi exhaust with fmf power bomb header pipe, 3x3 airbox mod and FCR carb..it seemed to be running lean and lacked power so i pulled the carb and it had a 150 main jet and needle was on second clip. dropped neddle to 5th slot and installed a 165 main and played with fuel(pilot) screw.2 1/4 turns out.runs better..question i have is i seen in a few stickys when you pull the screw that holds the needle in that there is a spring type thing on it..mine never had that..do i need to order one or is it ok?been thru a few 4 wheeler carbs but this is my first DRZ . it comes right up in first now no problem but still struggle to power up in second gear..15/41 sprockets..is this normal for a drz..with a 200lb rider?
Posted 13 April 2012 - 12:31 AM
For big bore use 155mj...
If it is Fcrmx ...Spring and collar is required
Coil spring. Part No.1290-A65-200
Collar ........ Part No.1118-B36-20000
243 and 244 on diagram...http://www.sudco.com/fcrmx.html
If Slant Body Fcr (stock E) no spring and collar
Edited by CraigoDRZ485sm, 13 April 2012 - 01:01 AM.
Posted 13 April 2012 - 12:57 PM
Posted 13 April 2012 - 01:31 PM
Posted 13 April 2012 - 05:38 PM
Posted 13 April 2012 - 06:05 PM
scites, on 13 April 2012 - 05:38 PM, said:
So does it look like this??
or like this with the coast enrichener removed
Edited by CraigoDRZ485sm, 13 April 2012 - 06:16 PM.
Posted 13 April 2012 - 06:51 PM
Posted 13 April 2012 - 07:34 PM
What did the needle have stamped on ?
Edited by CraigoDRZ485sm, 13 April 2012 - 07:36 PM.
Posted 14 May 2012 - 02:57 PM
Posted 14 May 2012 - 04:23 PM
