i have a lifam big bore kit for an 03 xr 50 and i am not sure if bbr makes an oil pump that will fit on it
xr 50 lifam big bore kit, oil pump
Started by
chriscap70
, Apr 12 2012 02:11 PM
3 replies to this topic
Posted 17 April 2012 - 03:59 AM
The oil pump goes on the right-side engine case, not on the bore kit. If you have an '03 XR50 engine, the BBR oil pump will work on it.
If you have a Lifan big bore engine in an '03 XR50, then you have to take the clutch cover off and see if the Lifan oil pump is the same.
