lastly- if i have a 10 yz, what year gears from the WR will work? thanks thumper buds!!
WR 4th & 5th on a 10 YZ450f?
Posted 10 April 2012 - 04:26 PM
Posted 10 April 2012 - 04:53 PM
The idea of using a WR 4th and fifth has intrigued me for some time now. It would be exactly as if you had a YZ450 4 speed with the WR 5th added on. Should be a very cool mod.
Posted 10 April 2012 - 07:35 PM
Posted 11 April 2012 - 06:22 AM
Posted 11 April 2012 - 06:33 AM
09 WR 4th gear has a 20T pinion, 21T wheel.........the 10 YZ 4th gear has a 22T pinion, 24T wheel.
it seems to me, in my uneducated guessing that the yz should pull longer then the WR in 4th gear.
09 WR 5th gear has a 25T pinion, 21T Wheel........the !0 YZ 5th gear has a 21T pinion, 20T wheel
I have no idea what that means in terms of longer shorter gearing??
i bealieve that these are the only parts i will need to do this sweet mod
Posted 11 April 2012 - 06:43 AM
Your stock trans ratios are
1.929
1.533
1.278
1.091
0.952
With the WR top two they'll be
1.929
1.533
1.278
1.050
0.840
Posted 24 April 2012 - 06:50 PM
Posted 24 April 2012 - 07:04 PM
Looks like I didn't look into this deep enough, eh? Keep us posted.
Posted 24 April 2012 - 07:07 PM
Good info for when I am ready to upgrade my ktm race bike.
Edited by mauricedorris, 24 April 2012 - 07:09 PM.
Posted 24 April 2012 - 11:00 PM
grayracer513, on 24 April 2012 - 07:31 PM, said:
I am still planning on considering the yz as offroad race bike for the desert (assuming that there's any desert racing left in a couple of years)
I love the ktm, but I really miss the Yamaha reliability.
Posted 25 April 2012 - 07:56 AM
mauricedorris, on 24 April 2012 - 11:00 PM, said:
That truly is an endearing feature, is it not? That's one of the big reasons I'm on one.
My YZ450 works out very well for desert racing. No reason to de-tune it at all. The shortcomings it has are the close ratio gearbox, which we are talking about here, the lack of an e-starter, which is really only a big deal on the starting line, and not always even then if the bike is tuned right and you set it up right, and the lack of enough electrical supply to run lights. What I'd really like to do is find a complete crashed WR someplace so I could pick and choose parts from it.
The 2012 WR is a very tempting piece.
Posted 25 April 2012 - 08:24 AM
For desert racing, I don't see the tight gear box as a short coming. Nothing better than having two gears for a situation. But... I prefer the more technical races (enduros, H&H) where you spend quite a bit of time in 3rd and 4th gear and less time in 5th. The lack of an estart is not a problem. I have a ktm that lacks a kick starter. That isn't a problem either. So long at the bike starts, who cares how.
Yes, the new WR is intriguing. I know it rides light, but the overall weight is still a bit much.
Edited by mauricedorris, 25 April 2012 - 08:29 AM.
Posted 25 April 2012 - 08:47 AM
The low speed end of things I handled with a Rekluse, and it's no longer a problem. And you're right, close ratio boxes do have advantages. That's one reason I think the mixed gear box we're talking about would be so ideal.
Posted 02 September 2012 - 08:28 PM
Did you ever finish your trans project? Some of us are still on the edge of our seats.
Edited by PilotHonda, 02 September 2012 - 08:28 PM.
Posted 05 September 2012 - 06:20 AM
Posted 05 September 2012 - 06:24 AM
Edited by PilotHonda, 05 September 2012 - 06:25 AM.
Posted 05 September 2012 - 07:08 AM
My preference would be to use both 4th and 5th from the WR, as I suggested earlier. The result would be almost exactly the same first 4 gear ratios that the '03-'05 4 speed had, but with the addition of the high 5th gear on top. To me, that would be an almost perfect desert race box. As it is, at cruising speeds, there's not a lot of difference between 3rd, 4th, and 5th. Seems like the jump from the YZ 4th to the WR 5th would be kind of extreme.
Posted 05 September 2012 - 09:37 AM
