'03 450 Carb screw up...
9 replies to this topic
  • The Extractor
Posted April 10, 2012 - 03:24 PM
I failed to drain and clean my carb properly. I then took it way too far apart and cannot get the two mid body gaskets.
I was unaware that parts would be unavailable.
What should I do now?
Try to build the special o-rings?
Buy a carb off ebay for $250?
Will an 05 or newer work on my 03 450?
Thanks.
  • RasmusDK
Posted April 10, 2012 - 04:10 PM
Doh, well iam pretty sure i could have done the same thing =)
I think i would get one off ebay, get a 06+ they got a leak jet, if you dont have the hotstart by your clutch lever already you need a complete perch too, and check if the throttle are diffrent too. I got it all for my yz400 of a 08 for 220 dollars i think it was. It was all plug 'n play..
  • Rocky739
Posted April 10, 2012 - 05:16 PM
http://www.jdjetting...p?productid=132
Happen to see it when poking around, of course if I accidently took mine apart I'd be hard pressed to not put a Athena dual spray venturi jet in.. But I'm a weirdo
http://www.tokyomods...arburetion.html
  • The Extractor
Posted April 10, 2012 - 05:29 PM
Thanks I saw that gasket and called them but there is one more I need. I guess maybe I will buy another carb...
Mine has a hotstart.
Edited by The Extractor, April 10, 2012 - 05:30 PM.
  • Rocky739
Posted April 10, 2012 - 08:29 PM
Bugger, If its a regular oring a supply house should have one. Probaly order online and still be cheaper than a new carb.
  • The Extractor
Posted April 10, 2012 - 10:17 PM
Not a reg o ring or I would be roosting already.....
  • The Extractor
Posted April 11, 2012 - 09:26 AM
going to try see if I can get some made..... heres hoping. Maybe my old one is still in the trashcan....
  • Krannie McKranface
Posted April 11, 2012 - 09:32 AM
You should be able to make one out of the blue high-temp silicone, no problem.
  • woods-rider
Posted April 11, 2012 - 09:40 AM
Liquid gasket? Wouldn't be the cleanest or prettiest way, but would probably work if you were careful.
Edit: Krannie beat me to it.
Edited by woods-rider, April 11, 2012 - 09:41 AM.
Posted April 11, 2012 - 02:52 PM
...and I'm keeping score....
