Huge stumble/flat spot with Mikuni HSR 42mm
6 replies to this topic
  • jonr3
Posted 10 April 2012 - 09:12 AM
I've got a Mikuni HSR 42mm pumper on my Honda XR650L.  When I'm steady (not under load or adjusting the throtle) at around 3800 rpms and half throttle, it starts sputtering and cutting out.  If I give it a little more throttle or change the rpms it goes away.  This RPM/throttle setting is the only time it seems to do this.  Any suggestions?  Thanks
My carb is set up as follows:
150 main, 22.5 pilot, 1.75 turns, 96 needle, centered clip
My engine is:
2.41mm over bore
10.5:1 comp
MegaCycles cam
ported head
FMF powerbomb headpipe
ProCircuit T4 muffler
Elevation:  1100 feet ASL
  • Eddie Sisneros
Posted 10 April 2012 - 09:49 AM
better or worse as the engine gets hotter?
  • jonr3
Posted 10 April 2012 - 10:12 AM
It doesn't seem to make a lot of difference, but maybe a little worse when it's warmed up...
  • jonr3
Posted 12 April 2012 - 06:42 AM
Any suggestions?
  • jonr3
Posted 13 April 2012 - 07:28 AM
Eddie,
I rode it to work this morning - 32 degrees outside air temp - and did not notice any problem...
  • goosey
Posted 16 April 2012 - 06:21 AM
that was a perfect observation, it likes more air, so when it gets warm you'll have less air - so you'll need less fuel. put the needle down one clip position and you should be good!
  • jonr3
Posted 16 April 2012 - 09:30 AM
Awesome!  I'll try it this weekend.  Thanks!
