front sprocket
19 replies to this topic
  • ohiostate
Posted 09 April 2012 - 03:12 PM
<p>put a new front sprocket on last august. should it be doing thishttp://i1090.photobucket.com/albums/i367/pse1/IMG_1126.jpg  don't look right to me the old sprocket is about 1/4 inch bigger.. old sprocket is a 13 tooth new is 12.. win you put the sprocket on. the numbers should be facing you??  that is way i had it on.. both is about 1/4 wide.. http://i1090.photobucket.com/albums/i367/pse1/IMG_1124.jpg  should i replace the new 12 tooth sprocket???? it's about 6 month& old got a few more pictures http://i1090.photobucket.com/albums/i367/pse1/IMG_1126.jpg
  • ohiostate
Posted 09 April 2012 - 03:15 PM
http://i1090.photobucket.com/albums/i367/pse1/IMG_1126.jpghttp://i1090.photobucket.com/albums/i367/pse1/IMG_1124.jpg   see if the pic work now
  • Metalman62
Posted 09 April 2012 - 05:10 PM
Wow
  • JoeMcLaughlin
Posted 09 April 2012 - 08:07 PM
  • JoeMcLaughlin
Posted 09 April 2012 - 08:09 PM
A few questions for you. Did you replace the chain and rear as well? When is the last time you checked out the swingarm and rear wheel bearings?
Joe.......
  • ohiostate
Posted 10 April 2012 - 11:53 AM
the bike is new got it june 2011.. the back sprocket and is same that came on it.. how can you tell if the chain is bad??? measure the over all lenght?? will post a few pic of back sprocket and chain.. thanks joe fore getting the pic up .. going to get a new front sprocket maybe a back..   WORM
  • ohiostate
Posted 10 April 2012 - 01:39 PM
got a few pic hopefully http://i1090.photobucket.com/albums/i367/pse1/IMG_1131.jpg   http://i1090.photobucket.com/albums/i367/pse1/IMG_1135.jpg   http://i1090.photobucket.com/albums/i367/pse1/IMG_1137.jpg
  • JoeMcLaughlin
Posted 10 April 2012 - 03:33 PM
Posted Imagehttp://i1090.photobu...e1/IMG_1135.jpgPosted Image
  • JoeMcLaughlin
Posted 10 April 2012 - 03:39 PM
For the chain I take it off and place it on the floor, if I can arch it into a half circle I replace it. Someone recently told me that is not a very accurate way of judging the wear of a chain but that is what I do. Every year I replace the chain and sprockets. I just did the kids bike yesterday and his chain is stretched about half an inch longer than a new chain. Also his rear sprocket is wasted. Your rear does not look bad but something is not right because your front is wearing like it is out of alignment. Is that the OEM front sprocket?
To insert a picture just use the image link. You already have the URL just click the image link, paste it in, and click ok;) It is the little icon that looks like a picture.
Joe........
  • ohiostate
Posted 10 April 2012 - 04:50 PM
the one that has 13 on it is the one ktm put on it... the 12 tooth is a sunstar has the number 357 on it  got a local dealer to order a moose racing front sprocket.. hopefully it is better than a sunstar???  who makes sprockets fore moose??? renthal??? the sunstar might be made of softer cheap steel???      500.33.029.012 35712 520-12  got this from sunstar web site  dont say the bike size..  might email sunstar a pic and see what they say...  thanks fore the help    WORM
  • gmoss357
Posted 10 April 2012 - 04:57 PM
Do you ride in a lot of mud and/or grit?  I have had them do that.  chain too tight?
also, the smaller the sprocket, the tighter the turn the chain has to make, which is more wear on the front sprocket.  When I had the issue, it was with a 13 tooth, ran nearly too long.  I have had much issue with that since running a bike that takes a 14 tooth.  The 12 is just about too small for the chain to turn.  I think this is the core of your issue.
look at the 12 tooth, you can see where each link connection is and how tight/pointed the wear point is compared to the 13 tooth.
Edited by gmoss, 10 April 2012 - 04:59 PM.
  • Shady802
Posted 10 April 2012 - 05:07 PM
I don't think I'd blame the sprocket on that one.  Does the other side look the same?  I'd suspect a serious misalignment of something to have shaved the sprocket like that.  Considering the amount of wear and the inevitable metal shavings from that, I think it would be worth considering replacing the chain now due to the potential damage from this condition.
  • JoeMcLaughlin
Posted 10 April 2012 - 05:08 PM
Here is what I just took off the kids bike. He ran the Grand Prix series and Endurance series Ironman so he has put a lot of wear on parts. There parts were new in Feb 2011. He ran a 13 /50 last year on the 150. This year we changed it up to a 14/50. I ordered o-ring chain by mistake this year. Normally we run the non o-ring chains.
Joe...........
Sprockets with one year of use:
Full size: http://www.tripleate...-1/DSCN9967.JPG
Chain, new on top,, one year of wear on the bottom:
Full size: http://www.tripleate...-2/DSCN9968.JPG
  • JoeMcLaughlin
Posted 10 April 2012 - 05:12 PM
Oh ya, the old chain is about a half inch longer than the new. It has stretched that much. That notching on your 12 tooth front looks very odd to me. I get what Gmoss is saying about the tight turning of the chain but I'm not seeing abnormal wear on the 13 tooth so I would be wondering what is up with that funkiness.
Joe.........
  • ohiostate
Posted 10 April 2012 - 05:54 PM
had the 13 sprocket on the bike fore about 3 month's the 12 is about 7-8 months old.. Do you ride in a lot of mud and/or grit? had a lot rain this year a little last year.. I clean the chain after every ride.. wd-40, chain wax      I have had them do that. chain too tight?  about 3 fingers maybe a hair more...  Does the other side look the same?   no looks almost new  cannot figure that one out one side looks like ??? other side looks new...http://i1090.photobucket.com/albums/i367/pse1/IMG_1138.jpg
  • gmoss357
Posted 10 April 2012 - 06:09 PM
Mud and the tight turn will cause that, and the tighter the turn, the more the wear.  Mud is a part of riding here and when I was racing a full series, we ran lots of mud races.  That wear was common.
Do you run the stock chain guard?
Edited by gmoss, 10 April 2012 - 06:21 PM.
  • ohiostate
Posted 10 April 2012 - 06:10 PM
  • piercebronkite
Posted 11 April 2012 - 06:46 AM
What are the tell tale signs of a worn front sprocket? Is it the "slanted points" like JoeMclaughlins picture?
  • gmoss357
Posted 11 April 2012 - 12:37 PM
yes, front or rear, the teeth get "hooked" on the pull side.
  • ohiostate
Posted 12 April 2012 - 12:21 PM
got a few more pic the sprocket is a pcs of ????.. http://i1090.photobucket.com/albums/i367/pse1/IMG_1145.jpg  picture 1145 you can see the chain running to left.. way from engine... the sprocket is dished out on the side that is bad.. only way i can explain it.. one more pic http://i1090.photobucket.com/albums/i367/pse1/IMG_1144.jpg
