Hi i noticed my front pads on my 125 sx were getting thin so i decided to change them but the pin that goes through them both seems to be siezed and rusty any help?, i tried abit of wd40 but no look, i made sure not to get it on the disks
thanks
matt
Stuck brake pad pin
Started by
mattylfc
, Apr 09 2012 09:30 AM
5 replies to this topic
Posted 10 April 2012 - 03:04 PM
lookntoride, on 10 April 2012 - 05:57 AM, said:
Try a SMALL ball peen hammer and tap the end of the pin, just lightly to break any corrosion.
There are much better true penetrating substances than WD-40.
If I have time I will pass on the name of a food penetrating oil, I just have to find the name.
Hi i ended up getting it out small taps didnt work big hits with a sledge hammer didnt work , tried penetrating fluid jaguar use that didnt work ended up cutting it with a hack saw then it came out nicely with a hammer and impact driver, the man in a local shop said to stop it happening put grease on the pin and it wont sieze up, Thanks for the advice:)
thanks
matt
Posted 10 April 2012 - 03:39 PM
is it like a yamaha were theres a cover then a allenpin
tusk makes a pin kit to replace the cover and turn it into a hex head
Posted 10 April 2012 - 03:51 PM
the penetrating juice is Kano Kroil or aerokroil.
I did some research and it seems to be possibly the best.
Glad you got it out.
Also the grease- look into a good High heat maybe marine or Water proof grease.
I wonder if one of the different types of anti seize would work? I have never used it where it would get wet and hot all the time.
Good riding to you.
Good riding to you.
