another spring question
3 replies to this topic
  • luvnoldcars
Posted April 07, 2012 - 01:29 PM
i have a 2012 yz450f with a 5.4kg rear spring that beats me to death on rough tracks. the free sag with this spring is 42mm and race sag is 99mm. will a 5.3kg spring get me to 30 to 35mm free sag and smooth things out or should i go with a 5.2 spring. almost forgot i weigh between 155 and 160lbs depending on the day (without gear).
  • FZ1426
Posted April 07, 2012 - 08:10 PM
Put the stock spring back on. You've got too much preload on the spring.
Posted April 07, 2012 - 08:54 PM
Explain
Posted April 07, 2012 - 09:05 PM
Either a 5.2 or a 5.3 should be right. The 5.3 might not get you the sag reading you want, but it will be closer than what you currently have. If you're a fast MX type, choose the stiffer one of the two. If the bike is beating you up, spring rates might not be your only problem.
  • Hot  36 replies
  • Hot  113 replies
  • Hot  38 replies
  • 5 replies
