Got some more time on it today. Drained the oil(or lack thereof) from the frame, engine, and filter. Just a bit from the frame and engine, more from the filter. I'm assuming they drained the oil before beginning to work on it. Good new is - all was free of any debris!
Pulled the cylinder jug off- piston, rings, walls, cam chain, and tensors all appear to be OK. Doesn't look like there was any valve to piston contact. There was a small spot on piston that looked rough(see photo.) Minimal side play in the rod, and was able to smoothly turn the engine over by hand. I feel pretty comfortable that the bottom end is still in good shape.
Will be inspecting the idler pump gear, and cleaning all parts this weekend.
The head i bought just shipped today, and I'll be getting a set of stock S cams from local member. Guess I should go ahead and get new gaskets all around.
New Questions:
- Should I go with the E gasket upgrade? Have heard of it but haven't researched it much
- Should I replace the piston and rings? Or could i get away with just new rings?
- Is there anything else I should replace other than just gaskets?
Photos:
Edited by steezin_and_wheezin, 13 April 2012 - 04:01 PM.
