Car engine oil for 4 stroke bike?
6 replies to this topic
  • wrwest
Posted April 03, 2012 - 12:33 AM
Can I use Castrol EDGE 5W40 in my 450 WR ?
Its a full synthetic oil.
  • hjorth
Posted April 03, 2012 - 01:38 AM
Hi
As far as I know you shall use JASO approved oil, otherwise your clutch will slip, because of some low friction additives in car oil.
  • Taxgod4u
Posted April 03, 2012 - 07:25 AM
Is Shell Rotella T, the diesel oil, still a good one to use for these things?
  • n16ht5
Posted April 03, 2012 - 08:02 AM
if it doesnt say "energy conserving" in the circle where it says the weight you are okay.
yes shell rotella t is good, I used it for years.
I run Valvoline racing synthetic. its fairly inexpensive ($5-6 qt) and after searching peoples oil analysis's it holds up really well compared to stuff like amsoil
  • Stealth13
Posted April 03, 2012 - 08:37 AM
I use rotella t diesel in mine.
  • hjorth
Posted April 03, 2012 - 10:34 AM
Hi
CASTROL EDGE 5W-40
  • API SM
  • SAE 5W-40
  • ACEA A3/B4
  • Approved for VW 502 00/ 505 00; BMW Longlife-01, MB-Approval 229.3, Porsche A40 (refer to vehicle manual)
This oil I would not recommend for a wr450, from API SG and newer, low friction additives were added, (like zink liniment)
You could use it in a ducati motorcycle with a dry clutch.
I have destroyd the clutch in my honda cbr 900rr fireblade with car oil, it did not help to change back to proper motorcycle oil, I had to change the frictionplates in the clutch.
  • surveydude
Posted April 04, 2012 - 07:36 AM
Possibly a stupid question here but here goes. I often see mention of Shell rotella diesel oil being used. I used Delo 15/40 for many years (in two strokes) with great success. Seeing as i'm having a complete rebuild top and bottom done on my WR400 (sone to be WR426) would Delo be a good brand to use. I can get the Delo 1-5 gallons at a time so it would be cheap for me but not worth hurting a new motor. Thanks in advance.
