yz450f quick throttle kills engine
8 replies to this topic
  • spiceman
Posted April 02, 2012 - 10:41 PM
i have a yz450f i bought recently.
even when warm, if i very quick snap the throttle from an idle. it dies instantly. is there a quick fix i can do to stop this? bump the idle up a tad? anything?
the guy i bought it from said it had a "poison jet" i have no clue what it is, but i'm assuming its been jetting up a bit.
  • Hurky
Posted April 03, 2012 - 02:51 AM
Look @ this:
http://www.thumperta...minate-the-bog/
http://www.thumperta...400426450-faqs/
Regards
  • Stealth13
Posted April 03, 2012 - 06:09 AM
Maybe dumb but is the gas turned on? Mine did the same thing then I switched it over to on
  • travertt
Posted April 03, 2012 - 06:32 AM
You may have more and better results if you post this on the YZ forum.
  • spiceman
Posted April 03, 2012 - 09:10 AM
ah it was late i thought i put this in the yz forum, someone who can. please move it
  • MANIAC998
Posted April 03, 2012 - 03:49 PM
No idea what a "poison" jet might be!! Perhaps you misunderstood him, and he said "Boyesen", as in Float bowl for the carb? Maniac
  • hjorth
Posted April 04, 2012 - 10:55 AM
I thourght this was normal with a flatslide carb, you have to "roll" the gas on.
On the WR range with the mx-fcr carb an acc. pump was added, and helped a bit on this.
With my wr426 i can provoke the same, but when driving, It never seems a problem.
Cv carbs do not have this issue, but not as much fun..
  • spiceman
Posted April 04, 2012 - 11:43 AM
yea when i'm riding, i never notice. but it does happen if you try to take off from a stop and are too quick on the thorttle
  • MANIAC998
Posted April 04, 2012 - 03:50 PM
No, that's not normal. Or more correctly, it might be normal, but can be eliminated with the proper jetting, fuel squirt, etc., etc..
Maniac
