Fork Fluid Question
43 replies to this topic
  • Ga426owner1
Posted August 30, 2001 - 09:24 PM
DaveJ, on the quality of fresh oil issue. I had just changed fork oil less than 2 mo. ago. After completely cleaning tubes, all internals & removing Compression valve to clean, I tried Silkolene 5w for a change (probably never again). I have about 6 rides, including 2 races on these forks. Would heat affect oil flow - as temp. here go from 70's in am to 90's in afternoon?
  • SUnruh
Posted August 30, 2001 - 09:29 PM
i have the bottoming cones in my forks. they are SUPER!!! my friend john (emaracing) had them in his forks. he loved them as well. they really do allow you to control the bike as it bottoms. worth every penny in my book.
scott f,
i don't worry about fluid. my '98 had the forks done by Factory Connection in july of '99. in july of '00 i sent them back. they wanted to know if i had even ridden the bike. yes, it had 18 races (all harescrambles) on them. they were shocked at how clean the fork oil was.
fixing the mid-valve can be done by any of the 3 guys i mentioned above as well as putting in the cones.
  • Ga426owner1
Posted August 30, 2001 - 09:42 PM
DaveJ - another quest. I see racetech & others have a midvalve replacement part to change to a checkvalve. What are your thoughts of this. Just remove it all together,replace with checkvalve....
  • Scott_F
Posted August 30, 2001 - 09:52 PM
The bottoming cones are worth every penny, and they are easy to install if/when you go in deep enough to fix the midvalve.
When I say midvalve, I am talking about the comp shims on top of the rebound piston. These shims flow a lot of oil, and can be damaged or wear out. They can be removed/disabled, which will give a lot of plushness for off road riding, but for jumping it is better to leave them in. These shims can be replaced, or the stack can be changed for more or less stiffness.
Steve, as long as the oil is clean, that's the main thing. We've all seen smelly gray oil come out of poorly maintained suspension. That stuff is like lapping compound. Fortunately, our modern suspension has anodizing on all aluminum parts, so oil stays cleaner much longer.
Ga426, heat and viscosity breakdown are not much of an issue in forks like it is in shocks. A high VI or viscosity index means that the viscosity is stable over a wide range of temperatures. Hi-rollers can use shock oil in forks for the highest VI.
  • Ga426owner1
Posted August 30, 2001 - 09:54 PM
Guys, who sells these bottoming cones???How much $???
  • SUnruh
Posted August 30, 2001 - 10:07 AM
i had mine put in by jeff at
like i said, any of the 3 can do it and are very knowledgeable.
price is like 160. jeff might even fix the mid-valve cheap if he's doing the cones.
in my FC setup the mid-valve was taken out. in the TrakControl setup it was left in and jeff knows how to set it up right. even for offroad (about all i ride). the TrakControl forks whip the pants off the FC ones. period.
[This message has been edited by SUnruh (edited August 30, 2001).]
  • DaveJ
Posted August 30, 2001 - 02:16 PM
For bottoming cones check out anti-bottoming systems at the following web site.
And I saw an ad in one of the moto mags showing a picture of the same cones sold by Factory Connection. I'm not really sure who is the OEM on this, but I think it's C-Cycle.
And ScottF and the rest of us are referring to the mid-valve as the stack of shims residing on the opposing side of the rebound piston. This is the piston that is attached to the end of the cartride rod, inside the cartride, moving up and down with each stroke, (the compression piston just sits at the bottom, which is why perhaps some people just call it a valve).
So, unlike the compression piston (er...valve), the mid valve shim stack has a lot more movement or flexing of the shims. I once spoke with Scotts and White Brothers about this and both mentioned the use of a backing plate against the stack to avoid excessive flexing.
This worked, but the harsh ride continued.
When I spoke with KYB about this, they said to just remove the stack, but that they were not offering replacement pistons in this size to re-regulate the flow of oil on the compression stroke as they did with other fork design. Who knew?!
Keep in mind that the compression stack and valve on the bottom of the fork only flow a small amount of oil during the exchange or stroke of the fork.
So I pulled the mid-valve stack and installed a check plate. Then used a restrictor plate that I acquired from Race-Tech from either an earlier experiment with this fork, or something I have built in the past.
The problem is, the Race-Tech restrictor plate, which resides underneath the seal head (the cap of the cartridge tube) does not work with the after market bottoming cones.
Mainly it doesn't allow enough oil to bleed through, which traps air in the cartride tube.
So a bleed spacer needs to be made to go between the two of them, (bottom cone and restrictor plate). A bit of garage engineering. Thickness is critical so that the bottoming cone will mate with the top of the cartridge tube.
As for the longevity of oil, I was beating my bike heavily for about 10 to 15 hours of operation before I noticed serious degradation in performance. With each exchange, I tried a different brand of oil until I found that the KYB 01 distributed by Enzo Racing worked best.
One last note. The factory seal heads also have a shim stack in them. They can only be accessed by grinding off the bottom of the seal head. It’s a useless effort, but it’s worth noting that this assembly can get packed with the residue that ScottF is mentioning, causing it’s own set of issues. These sealheads also offer some hydraulic bottoming resistance, but no more than ¾ of an inch or so.
The aftermarket seal heads (bottoming cones) don’t use a shim stack, and offer about 2 inches of bottoming resistance. Just right.
  • Scott_F
Posted August 31, 2001 - 06:11 AM
You just read more good stuff from DaveJ.
As for the base valve, it flows about as much oil as the cartridge rod displaces when it plunges down into the cartridge. So, some oil gets pushed out of the cartridge through the base valve, and some flows through the midvalve.
  • Ga426owner1
Posted August 31, 2001 - 08:38 AM
Scott F if I understand correctly, you prefer keeping the "midvalve / top valve" in place, especially for Jumping.
DaveJ you prefer replacing it with a "check plate" type of device which makes the forks behave like older style 2-3yrs older style used to be w/o the midvalve.
Scott F -- MXTuner - Mark Klein wants to remove the top valve because he feels they are defective or relocate them farther down the rod. What are your thoughts on this? By the way - Mark told me to tell you hello.
Do either of you see any advantages to leaving this valve in place or removing it all together. This is where I get a little confused.
  • Dave_S
Posted August 31, 2001 - 09:52 PM
Ok, maybe a little light is going on now.
BTW, this is a question, not an answer... :)
The base valve is the 'thingie' that you remove from the bottom of the fork to get the cartridge out, right? It of course has a valve stack that controls compression damping and a clicker for some adjustability of that damping.
The midvalve is inside the cartridge tube and ALSO has a valve stack that controls compression damping. So these valves work together (in parallel for those electrically minded types) to provide the total compression damping.
'Removing the midvalve' means to take the shim stack off the midvalve (seal head?) so that oil flows past it freely? or at least as freely as the valve design allows it to. Soft of like a calibrated leak. The check plate is required because the seal head is also the rebound damper and leaving the holes open would obviously allow oil to bypass the rebound stack and render it useless.
Is this even close to being right?
If it is, I would think the ports (holes) in the seal head would need to be pretty restrictive so as to allow for some control of compression damping at the base valve. What has me wondering if any of this is correct is that if someone is complaining of a 'blown midvalve' I am thinking that the midvalve is not doing its job of regulating oil flow therefor all the oil is going freely through the midvalve at the seal head and very little/none is forced out the base valve. This makes me think that removing the midvalve would never allow adaquate compressions damping because all the oil will simply go freely through the seal head and the base valve cant to its job.
What am I missing. Is a restrictor plate required to limit the oil flow by the seal head and I would guess the stack on the base valve NEEDS to be adjusted to compensate for the differnce in its 'compression damping partner', the seal head/mid-valve.
(I sure it would be much more clear if I could just see inside one!)
Dave S
  • Scott_F
Posted August 31, 2001 - 09:59 PM
Yes, I prefer to leave it in for jumping large jumps. You need all the compression damping you can get when you squash it like you did it that photo. It's hard to describe these things in great detail unless you are quite familiar with how it looks, works and goes together. I don't know what is meant by "relocate" the shims, but you can move the "open" position slightly closer or farther from the piston surface by changing the shim stack height or the collar height. The midvalve works like both a check valve and a shim stack. The shims are backed up by a spring, like a check valve. So when there is positive pressure on the bottom of the shims, they pop open a small distance, say .100", then they flex farther depending on the pressure.
When Mark says remove it, I think he means convert it to a check plate. I would do this for plushness, not bottoming resistance or jumpability. Mark knows what he is doing. He may have some setting that will work great for you. You could turn him loose on it, and if you don't like the result, you'll know which way to go from there. If you do disable the midvalve, the bottoming cones would be even more valuable/important for jumping. The cones also allow you to run a lower oil height for a smoother more linear stroke, while still providing bottoming protection with a big "slowdown" the last two inches.
Watch him do it if you can. It will be a good learning experience.
  • DaveJ
Posted August 31, 2001 - 10:20 AM
DaveS - You're spot on. And yes, the restrictor plate makes up (or blocks) the additional flow into or around the seal head. That additional flow of course is caused by removing the mid-valve.
So everyone should now conclude two things from all of this.
One, every manufacture is only designing their own little piece of what you take and make into the big picture.
Secondly, as ScottF has implied, there is more than one right way of doing something "right". His methods work wonders, and so do many others.
The bottom line, if you're a mad man SuperCrosser jumping machine (need I mention names), then I would stick with a version of a mid-valve installed mod that works for you. Bottoming cones a must have.
Crazy trail riders that love to hit a few good jumps and fly high, pull the mid-valve and replace with a check plate. Bottoming cones a must have.
Those traveling at a "let's just have fun speed", leave the bike alone and save yourself the headache.
If you like everything but hate the hoarseness, need I mention ultra-adjusters (that allow external adjustment of high and low speed compression.) See C-Cycles again. Not a bad quick fix for a few bills.
  • Scott_F
Posted August 31, 2001 - 10:22 AM
Dave S, you're getting warm! But I think you are confusing the seal head and the rebound piston. The seal head is the top cap of the cartridge tube. It is screwed in, locktited, and dimpled so as to never come apart. However, it is possible to break into that chamber, but it requires careful technique. You have to take apart the cartridge to work on the midvalve or rebound piston.
'Removing the midvalve' means replacing the shims with a check plate.
AFAIK, most or all of the oil that leaves the cartridge goes out through the base valve. I don't think the seal head flows much oil, and when you install bottoming cones, it leaks little to none. I would say they leak more under rebound than compression because there would be more pressure then.
I'm not claiming to know everything about suspension, I only know what I have done, and I learn more as I do more. These are only my opinions based on my experience.
Sez Dave: (I sure it would be much more clear if I could just see inside one!)
So tear your forks apart! :)
  • Scott_F
Posted August 31, 2001 - 10:27 AM
DaveJ summed it up nicely and I agree with his recommendations.
  • Dave_S
Posted August 31, 2001 - 11:48 AM
You are right, I was thinking that the seal head was the rebound piston. That helps alot. Thanks.
Suddenly your statement 'the base valve, it flows about as much oil as the cartridge rod displaces' makes obvious sense. since the top of the cartridge is sealed (seal head! :) ) the only oil that would want to leave the tube would be that that is displaced by the rod. Unless... Is there also a shim stack/valve under the seal head that allows oil into the tube?
I'm sure I will open the compression tubes some day soon but whenever spare time comes my way I seem to be ridin' more than wrenchin' !
BTW, Thanks for the info/replies it is ver helpful!
Dave S
  • Scott_F
Posted August 31, 2001 - 12:14 PM
I dismantled a sealhead once to check out the inner workings, and I did see some shims in there, but I don't recall what the function or oil path looked like. I don't remember if the oil can bypass the seal through the shims.
  • DaveJ
Posted August 31, 2001 - 02:45 PM
Well, it's sounds like the fork-chat thread is coming to a close.
What should we talk about now?
Any gossip out there?
  • Scott_F
Posted August 31, 2001 - 04:56 PM
It ain't over yet. :) After further thought, I remember that the seal head does flow some oil, I just don't know how much. I do know that if the shims in the seal head become damaged or fatigued, it will flow way too much oil, causing a lack of damping and a wrecked fork. The only fix is the Race Tech "block off plate" or the bottoming cones. Since the bottoming cones are "solid", the only leakage path is past the bushing, which would be negligible.
Sometimes these seal head shims get mistaken for the midvalve shim, as in "blown midvalve", but "blown seal head" would sound more appropriate. Neither one is a good thing.
Sound right Dave?
  • Ga426owner
Posted August 31, 2001 - 06:18 PM
DaveJ,Dave S, Scott F --- thanks for the lession in YZF Fork Physics. You have enlightened several facts that I never considered for setting up these forks, as well as realistic "internal specific tuning" ideas, thanks. I believe the "magazines definition of Blown MidValve" is far too vague & possibly wrong. Now it is time to rebuild & test.
  • Dave_S
Posted August 31, 2001 - 07:33 PM
Not so fast, I'm a slow learner :)
I know you have been all the way through these forks. Is there a shim stack on the bottom of the seal head? It seems that if there was, it would have a significant role in balancing the flow through the rebound piston/mid-valve path and the base valve path during compression. Restricted oil flow into the cartridge tube from the seal head (top) would force more oil through the mid-valve because if oil cant come in above the rebound piston, it cannot displace oil out the bottom. Is the seal head merely a check valve or does it also have valving shims?
I guess this is a good a time as any to admit my stupidity... I have been checking the oil level with the compression rod extended. I just looked in the manual and it says to check in with the rod fully compressed. I wonder how much extra oil I have been running! That explains why they are so much stiffer than all my friends bikes! DOH!
Dave S
[This message has been edited by Dave S (edited August 31, 2001).]
  • Hot  491 replies
  • Hot  28 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
