3 replies to this topic
  • ill_caper
Posted October 15, 2003 - 02:26 PM
I just cant seem to get it right. It rips on top. It rips good throughout the entire range but still backfires on decel. THe fuel screw is turned out almost 4 turns. It takes a while to start cold now too and is backfiring when I try and start it. Does anyone have any ideas? Setting are in my sig except for fuel screw, which is turned out more. Any help would be much appreciated. Thanks, D :D :) :D :D
  • Indy_WR450
Posted October 15, 2003 - 02:28 PM
Try a 48 pilot jet. and try position #5 on the needle clip and move up to a 72 starter jet for cold conditions :)
  • RichBaker
Posted October 15, 2003 - 03:00 PM
When everything is correct, there WILL be a little popping on is normal; throttle closed means high vacuum and rich mix exiting the exhaust system. When it hits open air the unburnt fuel burns.....
  • James_Dean
Posted October 15, 2003 - 09:50 PM
Try the blue marked needle in the 3rd clip position. It will richen 0-1/4 throttle only and will not need the fuel screw turned out as far.
