Control in the woods?
Posted 27 March 2012 - 07:50 AM
And another big heated debate is the kouba link or any lowering link for that matter woudl it really hurt my control immensly or would i feel a big difference. Im a big hare scrambler and ive rode bikes i could usually touch and it really helps in almost any situation. Im not looking to completely flat foot although that would be nice i just want to be able to set my feet down without having to find a rock or log. I just want to be comfortable. Thank you in advance.
Posted 27 March 2012 - 08:54 AM
Posted 27 March 2012 - 02:33 PM
Posted 27 March 2012 - 09:53 PM
I would definitely recommend getting the suspension setup better for your weight and riding level. Your spring rates look ok, although I would probably go one rate softer on the rear. Having the correct spring rates will likely help with the height of the the seat if you have your sag adjusted to the 100-105mm range currently. After going to a softer shock spring (compared to what you are running now), you should notice the seat being a little lower.
If you can afford it, I would look at having your suspension revalved for your weight and riding level. If you have the mechanical ability, you could revalve it yourself with the help of some people on here. I just revalved my suspension for my 05 crf450R for hare scramble type riding and can tell a big difference between the oem valving and what I have now.
Posted 28 March 2012 - 03:09 AM
Posted 28 March 2012 - 04:16 AM
Softer spring don't make seat being a little lower. If the SAG is the same , seat height is the same.
Posted 28 March 2012 - 02:30 PM
Posted 28 March 2012 - 07:44 PM
brandonbell, on 28 March 2012 - 02:30 PM, said:
they are talking about revalving the suspension, your best bet is to take it to a local suspension shop and have it revalved to your riding style and type of riding. It is the best mod you can do to an mx bike for the woods
Posted 29 March 2012 - 06:45 PM
If your racing harescrambles, there will be AT LEAST 2 or 3 suspension guys at your races that can redo your fork/shock valving for offroad (softer initial stage than mx valving). i'm betting that if you don't go with expensive gold valves (race tech-i have em but i have $). Just an inexpensive revlave will be the best thing you can do, as it will work for you ALL the time, every moment your on the bike. I wouldn't lower the bike.. as someone correctly stated earlier, going with softer springs but setting sag the same will have the bike sitting just as high as it did with stock springs. but it will often be LOWER in the stroke as your going along the trails, you also use LESS FORK OIL for offroad/enduro so that keeps the froks lower in the stroke too.
Tires for sure are important. nothing like nice sharp edges if you have nice terrain. im 5'7" or so and race srA class on a crf450 so i know the deal. only issue i have being "vertically challenged" is the LeMans start.. i use a 8" cut down milk crate as a step. Some BIG log crossings are easier for big guys but i wouldn't worry too much.
Posted 01 April 2012 - 11:45 PM
Re-valving your suspension would be the best decision you could make for that bike.
I also like my bars fairly high and forward but its just preference, makes me feel more in control when I'm standing.
Posted 02 April 2012 - 07:51 AM
Posted 02 April 2012 - 09:18 AM
Posted 02 April 2012 - 10:03 PM
Posted 03 April 2012 - 08:11 AM
Posted 03 April 2012 - 10:12 AM
Posted 03 April 2012 - 11:45 AM
Paddy with power, on 03 April 2012 - 09:55 AM, said:
BUT if your suspension is not setup correctly for your weight and ability, you are probably wasting a ton of energy. Having a properly sprung bike will greatly reduce fatigue and help you ride the bike to its full potential.
Posted 03 April 2012 - 12:49 PM
slothinker, on 03 April 2012 - 11:45 AM, said:
Exactly! Think of riding a very rugged trail thats littered with rocks and stuff on a rigid mountain bike (no front or rear suspension), now think of riding the same trail with a full suspension mountain bike. You will become less tired on the full suspension bike than the rigid one, allowing you to ride a little harder and longer. Same principle with the suspension on our bikes. MX suspension is valved fairly stiff to ensure they dont bottom all the time on jumps and other obstacles. Riding MX suspension on trails with likely make you tired quicker since it is stiff and doesn't offer the small bump compliance like woods-tuned suspension does.
