Thinking out loud, 426, lights
4 replies to this topic
  • Cooter69
Posted March 25, 2012 - 02:52 PM
I have a 01 YZ426F and I would like to install a light on it. I have read around about doing a WR crank or having a battery to run the light. Yet, what if I go with this light http://trailtech.net...light_kits.html and put a voltage regulator on it to not over extend the factory 35 watt system. I just need some type of light for riding back to camp when the sun is setting and such. I do not mind it will get dim at idle and crusing around. Just looking to have some sort of light output cheaply. I have the light from a previous ride and it just sits. Wanted to ask before I tear into it and mess something up. Also what all would I need besides the regulator and a on/off switch?
Thanks.
Posted March 25, 2012 - 03:40 PM
You can't run lights off a totally stock YZ426 stator. You can get yours rewound to "try" to support 35w of power, or use the stator and flywheel from a WR426 or WR400. Changing the crank is only necessary with the 450's. You would have to do a floating ground modification to the stator, but that's easy.
  • Cooter69
Posted March 25, 2012 - 04:15 PM
Whew! You happen to know of were I could find a stator besides an OEM one? I looked on ebay and nothing. Guess I will look for one or just sack up and buy a OEM one. http://shop.thumpert...2001&model=6311 I would need part ref. number 1 and 2? Also by doing this then could I support a 55 watt HID?
Posted March 26, 2012 - 07:17 AM
Yes, #'s 1 & 2. You'll also need to perform this little bit of surgery:
http://www.thumperta...52#post10674552
Not sure what the total available wattage of the unit is in stock form, but it should support the light. Understand, though, that to use an HID, you'll need a rectifier, regulator, and a battery. HID's have require a major amount of current to start them up, and they have a minimum operating voltage, so if they drop below that at idle, they go out and need to be re-lit.
  • Cooter69
Posted March 26, 2012 - 06:15 PM
That surgery seems doable! From reading around says 120 watts :thumbsup: I know I will need the rectifier and regulator. You really think I will need a battery too? If I do need a battery I will just throw the halogen light on. Give me a month or two and I will have pics of the bike all done! Only thing missing is a light, has every damn bolt on part and then some on it LOL.
Edit, halogen light it is! I will need a battery so HID is a no go, oh well. That is what the two 8" ones on my quad are for LOL.
Edited by Cooter69, March 26, 2012 - 06:17 PM.
  • Hot  94 replies
  • Hot  47 replies
