oil is not getting through the motor
7 replies to this topic
  • tylerbrantner
Posted 21 March 2012 - 01:05 PM
i recently just went to change the oil in my 07 cry 150r and we put oil in it and no oil is getting through or coming out of the drain plug any help on what it could be?
Edited by tylerbrantner, 21 March 2012 - 01:07 PM.
  • weantright
Posted 22 March 2012 - 04:27 AM
Did you add the oil to the clutch side of the case? Are you draining from the clutch side? There are two oil reservoris, one for the motor and one for the clutch. Drain bolt on the bottom center of cases is the clutch side. Behind the shifter bottom side is the motor drain. You would have a major clog if nothing is getting by.
  • tylerbrantner
Posted 22 March 2012 - 04:43 AM
we added it to to the said by the header should we of added to the side of the clutch case?
  • weantright
Posted 22 March 2012 - 04:46 AM
Header side is for the clutch and is the clutch case. Above the shifter is the motor side. You need a service manuel from E-bay!
.64qt for both clutch and motor w/filter.
Edited by weantright, 22 March 2012 - 04:46 AM.
  • tylerbrantner
Posted 22 March 2012 - 04:54 AM
yes the clutch case is above the header we added almost a quart in a 1/4 and nothing was getting to the clutch case do you think we could just have a clog?
  • weantright
Posted 22 March 2012 - 05:00 AM
You added a 1+ qts to the clutch side (below the header) and nothing is coming out the hole you are pouring into? Can you see oil in the hole you are pouring into?
  • tylerbrantner
Posted 22 March 2012 - 05:04 AM
yes we added it to the header and we kept checking the dipstick and no oil was getting to the clutch case we tried to take out the drain bolt after adding the oil and no oil came out on the dipstick to see were the oil level was but it wasnt showiing up
Edited by tylerbrantner, 22 March 2012 - 05:05 AM.
  • weantright
Posted 22 March 2012 - 05:26 AM
Dipstick is for the motor oil which is filled at the dipstick hole. Empty motor oil is the drain bolt behind the shifter. Completely different side is the clutch. Fill hole is below the header and is checked by a fill level bolt on the side of the clutch case (side of the header). Drain bolt is on the bottom of the motor in the center. I always use .64 qts. and never pull the fill level bolt.
Clutch oil will never go to the dipstick!
