08 yz450 w/ stabilizer
6 replies to this topic
  • Towelie
Posted March 20, 2012 - 05:14 AM
I did search, there are lots of postings, but none that really fit what I want. Wondering if A) A stabilizer is worth it for mx riding only?
I read it will help my tired hands. Doctor finally got rid of the numbing I get but hands still get extremley weak after a few laps. Wide open tracks I can wide well cause I can short shift but tighter tracks I really struggle on.
:thumbsup: Scotts Vs the GPR V4: Both seem equal, leaning towards the GPR as it will fit under my flex bars where I need to buy some different cross bars from Fasstco to make the scotts work.
C) Used stablizers, run?
Thanks!
Posted March 20, 2012 - 09:01 AM
I use a Scotts. I won't ride without it anymore. It will help you relax quite a bit, and it's saved my butt a couple of times by controlling the deflection from hitting stuff at odd angles. They work really well. Scotts dirt stabilizers damp only out from the center, allowing the free return to center without resistance, so if buying used, be sure you get one made for off-road, and not a street bike. Mine was not only used when I got it, it was damaged from a crash, so I had to spend quite a while reworking it to get it right. I have no idea how old it even is, but I've had it on two bikes for about 6 years with no troubles. Scotts service and the the parts availability are outstanding.
The thing that will really help your hands is suspension. Front and rear. Once the bike becomes stable and planted, you can ride a lot "looser", and won't get stung so hard by the big impacts.
  • bg10459
Posted March 20, 2012 - 03:22 PM
IMO, a stabilizer wasn't / isn't necessary for MX riding, but I ride a YZ250 2T. I never rode a 450 MXer, so I can't say if it would benefit from one. I do like the Scotts stabilizer on my WR450, though, but that sees 60+ mph, rock gardens and the unforeseen obstacles that are common offroad.
  • Eric@ScottsPerformance
Posted March 20, 2012 - 04:34 PM
Thanks!
Just remember that if you run a damper for MX or anything with tight turns you will run our Low speed adjustment looser so you dont have to fight the bars when you turn, and you will use the High speed adjustment for any of those sudden impacts that want to twist the bars out of your hands. You will probably also want to run the Sweep valves to the most narrow setting so the damper breaks free quicker as opposed to a Baja type rider who will want to damper to perform for a long Sweep or range of turning. We do make a mount that will put the damper underneath the bars like what you were mentioning but it will raise the bars up one inch to make room for the damper to sit. Depending on what bend of bars you have you might be able to make the damper fit underneath the Flex crossbar so you dont have to raise the height at all or you can buy the special crossbars that you mentioned from Flex.
Thanks-
Eric
Edited by Eric@ScottsPerformance, March 20, 2012 - 04:35 PM.
  • Weapon X
Posted March 20, 2012 - 06:50 PM
I've run the scotts for a year now and race MX and also ride tight woods in the spring and fall. I also had both my hands fall asleep during races and tried fasst bars which did help and I love using but I now will never run without a scotts stabilizer ,the only little downfall is you have to cut the foam up on a bar pad if you have the over the bars unit like I have to make it a little safer for your face. You definetly can loosen up your grip in corners when using a stabilizer you have to try one.
Posted March 21, 2012 - 06:45 AM
The availability of an adjustable high speed circuit is another great feature, as is the adjustable sweep range. As far as "fighting the bars", though, maybe some can notice it, but I never have. It's weird, because with the bike on a stand, you can definitely feel the damper working, but underway, it just isn't that evident.
In fact, most of the time, you can't really feel it working at all, until you take it off one day and ride without it. That's an eye opener.
  • Weapon X
Posted March 22, 2012 - 07:23 PM
you almost feel naked on a bike without one after using one so long!
  • Hot  36 replies
Motocross
  • Hot  491 replies
  • Hot  113 replies
  • Hot  50 replies
