'03' wr450f intermitten spark/no spark
No replies to this topic
  • kaboobz
Posted March 19, 2012 - 10:02 PM
hi guys, ive got a 2003 wr 450f and im not getn any spark, it sparked when i plugged spark plug into coil wile i was holdin it to steel bit on bike, (M#$%^ F^%$), but then nuthin, i tested all ohms specs i could test with no running engine to manuel specs all was goog apart from 1 reading on coil i wasent to sure about, but coil worked ok on mates 2010 kawa 4stroke 250, so im guessing its cdi or stator, so i get ready to check it and i cant get crank case cover off is there a trick to it, all starter gear came out ok but it seems to be stuck on sumthin? i followed the strip down order in manuel,
1 shift pedal
2 engine gaurd (left)
3 cover (idel gear 1)
4 idel gear 1
5 bearing
6 shaft
7 crank case cover (left)
im stuck here the cover wont come off, what am i missing? would any1 no why its not coming off, thanx for any help guys
Edited by kaboobz, March 19, 2012 - 10:03 PM.
