Stripped Small Drain Plug
8 replies to this topic
  • KX-450f
Posted 17 March 2012 - 04:18 PM
Hi, I was changing the oil in my 08 KX450f and noticed the previously owner stripped the smaller drain plug.  I bought the bike about a month ago and was going to finally take it to the track.  I was planning on doing a Heli-Coil.  Does any one have any advice in doing this?  What size bolt is the smaller drain plug and what size Heli-Coil do I use?  I appreciate any help.  Thanks.
  • ktm450ds
Posted 17 March 2012 - 04:38 PM
heli coil should work I have tapped out the hole before with a bigger tap, and just bought a bigger bolt that would fit. It has worked so far, but that was a quick fix.
  • KX-450f
Posted 17 March 2012 - 05:24 PM
Thanks, does anyone know what Heli-Coil kit I need and the size of the small drain plug?
  • sherco67
Posted 17 March 2012 - 06:31 PM
use a time-sert if possible, but bolt size is 6X1.0, be sure to flush well, mine was close to stripping about 5 oil changes ago, and with such a small amount in crank valley, I just decided to leave it alone, tip from side to side while draining, when time for rebuild will fix it then with new time-sert.
  • KX-450f
Posted 18 March 2012 - 03:27 AM
Thanks Sherco!  I will check out a time-sert.
  • KX-450f
Posted 19 March 2012 - 09:40 AM
Has anyone re-tapped this small drain to a 7mmx1.25 or 7mmx1.5 instead of using a Time-cert or Heli-Coil?  Trying to decide what the best fix is.  Thanks!
Edited by KX-450f, 19 March 2012 - 09:40 AM.
  • kx450f63
Posted 19 March 2012 - 10:58 AM
If you fix it with any type of thread insert (off the shelf type) you now have steel threads instead of aluminum.  In this situation, much better in my opinion.
  • mx317
Posted 19 March 2012 - 04:34 PM
I have used a 1/4X20 SAE bolt in place of a stripped 6mmX1.00. Use a new crush washer and snug it up.
  • KX-450f
Posted 20 March 2012 - 05:29 AM
Thank you, great point!  Made up my mind to go with a thread insert.
