It is a 2004 and I have replaced the ignition coil with an aftermarket and a new. When I got it, it was missing the safety cap on the back that keeps the button presed in. I have tried pressing the button in and no luck. Could I just cut the wires and tape them together to bypass the switch? I was also told the magneto might be bad, where is that at?
I can not get fire on my Suzuki Quadsport 50
Started by
mclld
, Mar 17 2012 10:03 AM
1 reply to this topic
Posted 04 August 2012 - 01:44 PM
if you are referring to the kill switch......then yes you can cut it. but do not tape them together. when the two wires touch it kills the motor. what i have done in the past is just put a toggle switch on it. just remember to get it to run, the wires have to be apart and to kill it you just have to touch the wires together. ....... i hope this helps.
Suzuki
vinson 500ATV/UTV → Make/Model Specific → Utility ATV |
Suzuki
ltr reliabilityATV/UTV → Make/Model Specific → Sport ATV |
Suzuki
05 suzuki vinson 500 wont startATV/UTV → Make/Model Specific → Utility ATV |
Suzuki LT80 QuadSport 2006Suzuki LT80 QuadSport 2006 |
Suzuki LT80 QuadSport 2005Suzuki LT80 QuadSport 2005 |
