Chain rubbing shifter
3 replies to this topic
  • DPW
Posted August 22, 2001 - 04:14 PM
Does anyone else have a problem with the chain rubbing the shifter by the shift shaft ? The chain is tightened to specs. I replaced both sprockets with AFAM parts and replaced the chain with a DID 520VM X-ring. Anyone else with same setup? I don't know if the offset of the AFAM counter sprocket is less than the stocker. I didn't have the problem till I replaced the chain and sprockets.
Thanks for your help
Dennis
'99 YZ400F
  • F-Pilot
Posted August 22, 2001 - 06:33 PM
I can't see how it's possible unless you are missing the lower chain roller. Are you?
  • DPW
Posted August 24, 2001 - 02:40 PM
The lower chain roller is there, a bit worn though, but I wouldn't think enough to rub the top of the shifter
  • sirthumpalot
Posted August 24, 2001 - 05:00 PM
I took a close look at my '01 tonight and the only possible way that I see that the chain could rub the shifter is if you either 1) Had a super monster front sprocket, or 2) routed the chain incorrectly and under the frame bar next to the foot peg and under the bottom chain roller. Otherwise I don't see how the chain would ever reach the shifter... Are you sure it's tightened to spec?
  • Hot  50 replies
  • Hot  38 replies
  • Hot  113 replies
  • 5 replies
