No neutral
10 replies to this topic
  • BiG_BooGeR
Posted 15 March 2012 - 06:31 PM
I can't get my bike in neutral. It shifts to 1-5 gear fine. If I'm getting on it in first and try to shift to second I can't and have to let off a bit to get it in second sometimes. I can only get it in neutral with my hand, when I'm standing next to the bike. It will click past neutral to second or first and click and engage loudly. I can't put it in neutral while trail riding so my hand gets super tired after about 30 minutes of riding.
  • Small_Booger
First!
Buy a Kawasaki KX450F!
hahaha
Edited by Small_Booger, 15 March 2012 - 06:33 PM.
  • BiG_BooGeR
Posted 15 March 2012 - 06:32 PM
It's a 2007
  • corndog
Posted 15 March 2012 - 06:33 PM
Got any oil in there? How often do you change it?
  • BiG_BooGeR
Posted 15 March 2012 - 08:11 PM
I changed it an hour ago. I put the spec amount in. I just got this bike.
  • DrDuke
Posted 15 March 2012 - 08:13 PM
Well do you believe it is you or the bike? How long have you been riding? Can you get other bikes into neutral? Has this problem started recently? Have you owned the bike since new or bought it used? How long have you had it etc?
  • BiG_BooGeR
Posted 15 March 2012 - 08:16 PM
The oil is whiteish from the transmission. The darker in the front is the engine oil.
  • BiG_BooGeR
Posted 15 March 2012 - 08:18 PM
It's the bike. I had an R6 for 3 years and I can shift my friends 2007 kx450f into neutral. I bought it used in January. It was slightly difficult before, now it's almost impossible. I feel like the shift lever is too far forward from the foot peg too.
  • Shawn_Mc
Posted 15 March 2012 - 09:27 PM
Is neutral easier to find with the engine off? If so the clutch basket is probably notched and the plates are dragging a little bit.
  • BiG_BooGeR
Posted 15 March 2012 - 09:48 PM
Yes
  • Shawn_Mc
Posted 16 March 2012 - 02:21 PM
You may be loosing some cable travel if your clutch cable is worn out, which could make the clutch drag too even with it pulled all the way to the bar.
Check the clutch basket for notching (it probably is, thats what all that silver stuff in the oil is, the wear from the basket). And watch the bracket that holds the cable down on the engine. See how far its bending when you pull the lever in. If its too much, you may want to make a brace so you dont loose the cable travel because when that bracket bends over your not lifting the pressure plate all the way up. That doesnt free the clutch all the way and it drags.
Sounds like you may be a trail rider too. If you slip the clutch alot that will kill the basket too.
