clutch actuator mod
7 replies to this topic
  • kstout4life
Posted 15 March 2012 - 09:19 AM
does the actuator arm have to be from a yz400f? or can a 00 yz426f arm do the same? i searched on here but could not find if it needs to exactly from a 400, i can get one from my buddys 426 so im looking to be able to do the mod
  • Swede73
Posted 15 March 2012 - 06:27 PM
Ask if you can borrow it really quick and see if it works.
  • Charlie755
Posted 15 March 2012 - 11:16 PM
Enlighten me on this mod if you can Swede. I am rebuilding a 250F and if this makes pulling the clutch in easier I will just order the correct actuator from the dealership. Thanks. :thumbsup:
  • Swede73
Posted 15 March 2012 - 11:42 PM
Here is a link of what he is talking about. It's a few years old so I'm not sure if the 450 clutch arm will work or just the older 400. There is also a link to the actual magazine article. Scroll down to the bottom.
http://www.thumperfa...clutch_mods.htm
Edited by Swede73, 15 March 2012 - 11:45 PM.
  • Charlie755
Posted 16 March 2012 - 06:59 PM
Swede73, on 15 March 2012 - 11:42 PM, said:
Here is a link of what he is talking about. It's a few years old so I'm not sure if the 450 clutch arm will work or just the older 400. There is also a link to the actual magazine article. Scroll down to the bottom. http://www.thumperfa...clutch_mods.htm
Thanks Swede. I know a lot of tricks on these bikes but its nice to learn new ones. :thumbsup:
Edited by Charlie755, 16 March 2012 - 07:00 PM.
  • staflat
Posted 16 March 2012 - 11:16 PM
Cut and weld works also. Cut in half and then build up bout 3mm weld on one side then fuse back together.
  • Charlie755
Posted 16 March 2012 - 11:49 PM
I have a welder and am great at fabrication but am also a perfectionist. I looked up the link that Swede posted and I am going with the 5mm longer YZ400F actuater. It just looks cleaner. Thanks though. :thumbsup:
  • oldnbold
Posted 19 March 2012 - 08:44 AM
It's 5mm longer. No the 426 is not the same lenght as the yz400 '98 or '99 model. I have one on mine now and I've put them on all my 250f's. It makes for easier pull and I like the modulation better as the stock actuation is too much ON or Off for my taste. This mod lets you slip the clutch.
