What the hell have I bought ?
9 replies to this topic
  • zRussz
Posted March 15, 2012 - 08:24 AM
Hi, hope someone can tell me exactly what I have gone and bought. Here goes:
Frame Number CJ01C-011463
Engine number H303E-006569
Carb type Keihin FL AT CR marked 5BEI-00ME12
I bought this fairly cheap described as a 2003/4 YZ426. It ran great and was in good condition so didn't question anything as I was going to put it on the road.
It has a speedo drive on the front wheel and there is evidence of a yellow wire coming out of the stator, although there is no lighting coil anymore.
It has a decomp lever, but no hot start button. On the carb there is a bunch of wiring and a mechanism above the choke lever that looks like it may be a hot start device of some sort.
There are a bunch of wires heading into the crankcase by the gear selector.
None of the above adds up and I can not find anything similar on the web.
Its very hard to start full stop, and with no apparent hot start button.
Can anyone help ?
I'm in the UK by the way.
  • bdeemo
Posted March 15, 2012 - 12:55 PM
I think they stopped making the 426 in 2002...
  • DC_Excitement
Posted March 15, 2012 - 02:21 PM
did that frame number you have come from the stem? cause that number dosent make sence. get the vin # from the stem and i believe its the tenth digit that will tell you the last number of the year, EX: xxxxxxxxx5xxxxxxx would be an 05. i belive i herd that from a yammie guy somewhere
  • cowboyona426
Posted March 15, 2012 - 02:42 PM
He's in the UK, they have different VIN's over there.
Posted March 15, 2012 - 03:15 PM
The carb is from a YZ 400, probably a '98. No YZ/YZF had a speedo drive, WR's did. '98-'99 were YZ400F's. '00-'02 426's, and '03+ are 450's.
The engine size should be on the cylinder, on the front near one corner of the base.
  • zRussz
Posted March 15, 2012 - 11:58 PM
Many thanks for the pointers everyone. It transpires I have a 2001 YZ426F frame with a '98 YZ400F engine and carb with some WR bits fitted.
If I could reliably start the thing I would be happy as larry. But obviously during the engine swap they omitted to fit the older style hot start system.
If anyone in the UK has the necessary plumbing going spare I would be grateful to hear from them....
  • RasmusDK
Posted March 16, 2012 - 02:09 AM
You can see on the cylinder what the CCM is, if its a 400 there should be a pipe for a 6mm hose on the side of the inlet manifold, be sure its sealed! Ive never used my hotstart.. Not totaly true tho, once or twice maybe, but it has only been if I killed it on a hillclimb, you really dont need it. The right starting procedure is what you need, maybe a new plug too.
Do this:
Kick it till it gets at the hardest point. Then pull the decompressor and kick it 1 inch further, release the decomp lever, release the kickstarter so its all the way back and give it a solid kick. Dont twist the throttle! you will just drown it! of cource use the choke too while cold. Thats it! Some say they twist the throttle before kicking when its cold, but it shouldnt really be needed, I never needed to do that.
Cheers!
  • zRussz
Posted March 16, 2012 - 04:15 AM
don't laugh anybody but I made myself a YZ400F Hot Start system out of an old fuel cock off a mountfield lawnmower! It even has a built in filter.
New they are about £3.50 but I will supply them finished in red and with some fresh tubing for about £69.99, just let me know. ;-)
  • APlusAutoParts
Posted March 16, 2012 - 08:55 AM
yes 10th digit is the year f=85 g=86 h=87 j=88 k=89 L=90 m=91 n=92 p=93 r=94 s=95 t=96 v=97 w=98 x=99 y=00 1=01 2=02 3=03 4=04 5=06 6=06 7=07 8=08 9=09 sorry but i dont have anymore
Posted March 16, 2012 - 09:37 AM
2010 goes back to "A" and they run through the alphabet again. The letters "I", "O", "Q", and "U" are not used so as to avoid confusion with other similar characters.
http://en.wikipedia....l_year_encoding
  • Hot  28 replies
  • On January 15, 2017
  • Hot  50 replies
  • Hot  38 replies
