Which WR 450cold start procedure actually works?
9 replies to this topic
  • xrberg
Posted March 13, 2012 - 11:19 AM
did a search..lots of opinions
What is the definative coldstart method for a 07-10 wr 450F ?
Is there a factory suggested cold start method?
I'm tired of fighten it...
thanks
  • Stealth13
Posted March 13, 2012 - 11:25 AM
Open the choke, give the throttle 3 full turns to full throttle . Release the throttle and try and start . If it doesn't start give it 1 more full throttle and keep trying . Works for me
  • bg10459
Posted March 13, 2012 - 01:04 PM
step 1. get pilot jetted properly. Step 2. get starter jet jetted on the rich side. Step 3. follow above :thumbsup:
  • Stealth13
Posted March 13, 2012 - 01:37 PM
Mine has stock jets and starts in negative temperatures now :thumbsup:
  • travertt
Posted March 13, 2012 - 01:41 PM
Assuming its not -20 outside.....Then as described above except four twists of the throttle, and then a fifth if required, is what works on my bike. If that doesn't work...kick it..if it's set up correctly it will start.
  • Summit
Posted March 14, 2012 - 06:20 AM
I started my 05 the other day, hadn't been run since November. Tip it over towards you for a couple seconds until you see gas run out the overflow, set back up straight, one throttle twist, fired on secong crank from elec. starter. I never use kick starter, don't have to.
  • Snarfie
Posted March 15, 2012 - 04:58 AM
Yep, this is exactly right. If your bike is jetted correctly, it will fire right up every time.
  • stuntheavy
Posted March 16, 2012 - 06:00 PM
mine hasn't had electric start in ages. After the 400cc days, and those nightmares....I'm a bit shy about flooding my 03 wr450. I put the choke on, cycle it over with the kickstart a few times, bring it up to compression, and usually first kick, if it's an enthusiastic one, is enough to make her fire up. I've always had bad luck ripping on a 4-strokes throttle, but thats just me
  • Krannie McKranface
Posted March 16, 2012 - 06:41 PM
thanks
Step one: un-cork intake and exhaust, and re-jet
Step two: choke on, three twists, press the button
It's not Rocket Surgery.
  • L. Euler
Posted March 17, 2012 - 03:51 AM
Twist the throttle first does not work for me. Floods the cylinder. I pull the choke and hit the button, fires on first compression nearly every time.
Edited by GammaFunction, March 18, 2012 - 06:23 PM.
