suspension for harescrambles...
Posted 12 March 2012 - 06:11 PM
trying to find good suspension setup with just using clickers on stock suspension on 07 ktm 250sxf
dont have the money to send suspension out
so any and all info about how you run your suspension for the woods is appreciated!!
i understand to run compression softer for woods but not sure how to set the rebound on both the fork and shock and wether or not to adjust my high speed compression on shock
Posted 12 March 2012 - 07:07 PM
Posted 12 March 2012 - 10:43 PM
Posted 13 March 2012 - 04:33 AM
Dwight_Rudder, on 12 March 2012 - 10:43 PM, said:
ok thanks dwight i like your idea about the maximum oil level
im not going to crazy with changing up my suspension as i do race hare scrambles and hit the mx track quite often
Posted 13 March 2012 - 05:30 AM
Posted 13 March 2012 - 07:49 AM
Interesting, I don't think I've every read about that approach for a woods bike. It is always the opposite with low oil levels.
Posted 13 March 2012 - 07:56 AM
H-B-R, on 13 March 2012 - 07:49 AM, said:
Low oil levels ? Then you would have to run higher compression to prevent bottoming or too stiff a spring. That would give a harsh ride in the first few inches of travel.
Posted 13 March 2012 - 09:08 AM
Dwight_Rudder, on 13 March 2012 - 07:56 AM, said:
Posted 13 March 2012 - 04:41 PM
Posted 13 March 2012 - 05:03 PM
YHGEORGE, on 13 March 2012 - 09:08 AM, said:
Go to 2 1/2 wt PJ1 fork oil at max level . Increase rebound one click. Back off compression till you're bottoming lightly then go back in one or two clicks.
Posted 13 March 2012 - 05:04 PM
Posted 13 March 2012 - 05:10 PM
Edited by YHGEORGE, 13 March 2012 - 05:12 PM.
Posted 13 March 2012 - 08:42 PM
ATF fluid in forks at 325 ML (low limit)
3 clicks from full soft compression on forks
5 clicks from full soft rebound
Shock is
2 clicks in on compression
High speed full soft
5 clicks in on rebound
Handles big hits, roots and choppy stuff. No deflecting up front or swapping in the rear. Basically just enough compression in both to achieve this, and still not get beat up.
Sits ok in the turns, not as much as I'd like. Was going to up rebound damping next to see if it'll sit down.
Posted 13 March 2012 - 10:46 PM
YHGEORGE, on 13 March 2012 - 05:10 PM, said:
11.8" is 300mm. You will want 42mm static sag (+-2mm) and 75mm rider sag. My Husky WR125/150 came with .42kg springs. Thing rode like a chopper. I changed to .40kg and sags were perfect. (Surprised me. I thought I might have to go to .38kg)
I weigh about 185lbs naked.
WOW only 45-46mm sag. Maybe they meant static sag ???? That would have been close. I now have 40 static and 75mm rider sag. Run the minimum preload you can.
Posted 14 March 2012 - 08:13 AM
Posted 22 March 2012 - 05:55 PM
Posted 22 March 2012 - 06:17 PM
Posted 22 March 2012 - 06:23 PM
Posted 23 March 2012 - 06:25 AM
YHGEORGE, on 22 March 2012 - 06:23 PM, said:
