Tight Screws
6 replies to this topic
  • D37Racer_Ret
Posted October 12, 2003 - 11:05 AM
Just purchased an 02XR650R in process of uncorking and found several bolts way over-torqued by the factory. The 4 screws holding the carb float bowl are so tight the metal starts to turn to mush. Factory spec is 1-1/4Ft-lb. Anyone have any ideas to remove? Bike is unbelievable out of the box I love it! Need to get the new jet needle and clip position in. Thanks for any suggestions.
  • XR250rdr
Posted October 12, 2003 - 04:06 PM
They arent overtorqued really, but the steel screws in the aluminum carb body tend to freeze. I would just get them out however you can and replace them with stainless allen head bolts. And some anti seize would help too.
  • loufish
Posted October 13, 2003 - 05:36 AM
I have had the "pleasure" of uncorking several XRs, I've had to use a hand impact w/new phillips bits on more the one occasion.
  • JackAttack
Posted October 13, 2003 - 07:40 AM
After I rounded out all the screw slots on the carb float bowl. I just took the whole carb off the bike and grabbed the small screws on thier sides with a pair of pliers to loosen them free(replaced them). The small screw that holds the needle in the slide was the one to be carefull with. It is very soft, and there is not much room to work in there. I think I ended up cutting a slot in the top of the screw and it finally coming loose.
Ride On! :)
  • irondude
Posted October 13, 2003 - 10:14 AM
check out the archives for lots o stuff on uncorking....
b53e--third or fouth setting for clip, 68s, 175 main
Best is to slap on an Edelbrock...
  • JackAttack
Posted October 13, 2003 - 01:10 PM
That is the best idea of all! :)
Worth the $$$$ for me!
  • D37Racer_Ret
Posted October 14, 2003 - 05:53 PM
Hey Guys!
Thanks for all the help. I purchased some new screws today and will attack that carburator this weekend. :)
Washington
  • Hot  32 replies
  • 4 replies
  • Hot  29 replies
Honda XR650L 2016
  • 0 reviews
Fell Off Trailer by usafxr
  • Hot  43 replies
