06 yzf450 Help cant Figure it out.
7 replies to this topic
  • Vince911
Posted March 08, 2012 - 12:02 PM
So my customer brought in an 06yzf450. It acts like its running really lean. Backfiring, popping, shooting flames. With a minute or less its hot. I changed the gas. Changed the jetting. Adjusted the valves. Correct timming. Checked for an air leak. I can not figure it out. Nothing seemed to help. He does not want me to pull the head due to money. There is a rattle you can hear from time to time you can when kicking it over. So im sure its about to go. Any ideas or suggestions would be helpful.
  • cowboyona426
Posted March 08, 2012 - 12:08 PM
Is the plate in the carb slide in upside down?
  • Vince911
Posted March 08, 2012 - 12:16 PM
Nope its in right.
  • Vince911
Posted March 08, 2012 - 12:24 PM
Checked and adjusted hot start and enrichner.
  • CO_Rider
Posted March 08, 2012 - 02:53 PM
Not to second guess but I would check the valve clearence again. Just sounds like the symptoms. Have you checked out the exhaust packing?
  • Chas_M
Posted March 09, 2012 - 07:36 AM
Have you checked to make sure that the idle circuit is working properly? Have you cleaned or replaced the pilot jet?
  • CROGGR
Posted March 10, 2012 - 08:43 PM
Replace the o ring gasket on the slide plate and make sure the plate intself isn't cracked. Use a magnifying glass and make sure! I have fixed several yz's that have had the same problem, and also make sure the acc pump nozzle is squirting fuel!
Edited by CROGGR, March 10, 2012 - 08:43 PM.
  • yz450fcranker
Posted March 13, 2012 - 12:56 PM
open her up she might want a rebuild
  • 9 replies
Motocross
  • Hot  491 replies
  • 0 replies
  • Hot  47 replies
  • Hot  50 replies
