valve clearence
4 replies to this topic
  • mor
Posted August 20, 2001 - 06:57 AM
what should b the valve clearence on the yz426f 2000? never did a 5 valves head, is there anything special that i should know?
  • Scott_F
Posted August 20, 2001 - 09:44 PM
You need to know where your manual is...
  • mor
Posted August 21, 2001 - 04:09 AM
come on , i got the bike from new-york with out the manual and i can't buy one in my country, i would b happy if u tell me where can i order one in the internet...
till then whatis the clearence?????
  • jamracing
Posted August 21, 2001 - 07:15 AM
Intake: 0.15-0.20mm
Exhaust: 0.25-0.30mm
Remember to check it cold...
01' WR426
99' YZ400
87' FZR1000
Uh, like twist the throttle...
  • Boit
Posted August 21, 2001 - 07:43 PM
Scott is right. You really need the manual to know all the steps. The cams have large "C" clips that you need to be aware of. If you drop one of these into the chain cavity, you could be in for a major headache. Plus, you need the torque specs for cap bolts..etc.
Here a hint from Heloise. If you make a small scribe mark on the cam chain plate directly above the top center tooth on each cam, you can more easily reassemble the cams in the proper spot in the chain instead of trial and error. Getting the cams back into postion requires patience and this little technique can save you a bunch of cussing. The cam gears have a small index punch mark
that lines up at 12 o'clock when you get the crank lined up on it's proper timing marks. I make a very tiny "V" mark on the cam chain plate directly above these punch marks and use these indexes as a visual guide when reinstalling the cams.
  • Hot  491 replies
Need help by Goforaride
  • Hot  68 replies
  • Hot  36 replies
  • Hot  79 replies
