CRF150 Power-up from Honda....
7 replies to this topic
  • wpoling
Posted October 11, 2003 - 12:19 PM
What do I ask for to get this kit? I asked at the local dealer (BOZO!!) and they had never heard of it. I had the p/n's for the main jet and the needle, but not for the bushing I've read about that needs to be replaced. They said they could special order the parts if I had the numbers. Is there a p/n for the kit or a bullitin that gives the information I need?
Thanks,
Bill
  • socalxr
Posted October 11, 2003 - 06:31 PM
I would do a search through the mini XR forum, we had that discussion quite a bit. I'm sure someone posted the P/N's.
  • wpoling
Posted October 11, 2003 - 08:08 PM
Been there, done that. All I came up with was the part numbers for the needle and main jet. I did find a reference you made to some dyno testing that you did using the stock needle and the "NOZZLE" that came with the power-up kit. What is the nozzle?
Does this kit have a part number? I've read several references to a "bullitin", does it have a reference number on it that I could refer to with my local dealer?
Also, I read where somebody was trying to remove the vaccum contraption on top of the carb. Has anybody done this? Is it an emissions deal or something important?
Thanks,
Bill
  • socalxr
Posted October 13, 2003 - 07:52 AM
The nozzle is the long thing the main jet screws into.
  • wpoling
Posted October 13, 2003 - 12:31 PM
Does a new one come with the power-up kit? That's my question that I can't find the answer to. What comes in the "kit"? Does the "kit" have a part number of it's own? All I have right now is the number for the main jet and the needle. Any and all enlightenment would be appreciated!!
Bill
  • Paul_in_Wa
Posted October 17, 2003 - 04:26 PM
16012-KPT-921, CRF150F Full Power Needle
It includes 4 pieces: Needle, brass 'bushing', E-clip, spring that holds the needle assembly in the slide.
This bushing is different than the nozzle. You retain the stock nozzle, just replace the bushing. You remove the main/nozzle from the bottom of the carb. If you look down the throat of the carb, the bushing will still be at the base of where the needle passes through down to the main. Remove the slide/needle and push out the bushing. Replace that bushing with the new one. Be careful. I got too aggresive with my first one and ovalized it. It should be an easy but firm fit. Reinstall the nozzle/main and the rest of the parts.
That, an assortment of mains and a 42 pilot and you should be set.
Paul
  • wpoling
Posted October 18, 2003 - 05:20 PM
Paul-
Good info!! Just what I needed to hear!!
Thank You very much!
Bill
  • BWB63
Posted October 20, 2003 - 05:36 PM
Best setup for the CRF150 (staying stock and low $$) has been 115 main and 42 pilot, Uni air filter and opening up the air box, removing baffle out of spark arrester and bending back the baffles inside the muffler. If you know how to advance the timing four degrees, that makes a big difference.
2003 crf230f revival by DakMac
  • Hot  41 replies
Honda CRF230L 2011 by Chris.GVS
Honda CRF230L 2011
  • 0 reviews
Honda CRF230F 2016 by Chris.GVS
Honda CRF230F 2016
  • 0 reviews
Crf230f vs crf250x for casual trail by bikesandcars
  • Hot  25 replies
CRF230F Performance Piston Options by mixxer
