98 wr400- grey wire?
4 replies to this topic
  • pbgunrunner1
Posted March 05, 2012 - 07:44 PM
Hi, I just did the grey wire on my 02 wr426 w a headlight switch so I can go back and forth. My buddy has a 98 wr400 and asked me if his bike could be done, Im actually not sure! Does it work with the older wr 400s too? thanks!!!
  • anoldsman
Posted March 07, 2012 - 11:11 AM
Yes, you can do the "gray wire" mod on a '98 WR400. I'm not sure if it is in the same location as yours though.
  • travertt
Posted March 08, 2012 - 12:04 PM
Hey "pbgunrunner1"...did you find a major performance difference after you did the grey wire??
I'm not sure if it was such a big deal on the pre '05 bikes...I have an '04 (Canadian model which may not have the US EPA restrictions built in) with grey wire still connected and I have no problem getting the front end to lift or with power in general....so it would be great to have your feedback.
  • pbgunrunner1
Posted March 12, 2012 - 04:22 PM
I havent played with it much yet, but it seems like it has a bit harder hit in the mid range... Ill know more when I switch between them. On a side note- can/should that be done on the fly or w a dead engine only?
  • mikewrf18
Posted March 17, 2012 - 06:32 AM
With the engine off to change mapping, if you do it when the bike is running nothing will happen.
