Hello, I want to see if that happens to you while runnig feels a vibration in the feet.
if this is not normal,what can be happening? How can i eliminate that vibration?
Sorry for mi inglish
Urgent, vibration in RMX450z
Started by
Supichy
, Mar 04 2012 06:39 AM
3 replies to this topic
Posted 04 March 2012 - 07:45 AM
If your feeling vibration from the foot pegs its normally a sign of the main or big end bearing failure. i would drain your engine oil and look for shiny silver or bronze colured bits in the oil, and i would remove and open up the oil filter and take a look. I been where you are now and my bike had less than 50hrs when failure happened.
Posted 01 May 2012 - 03:35 AM
My RMX has done it since brand new and also a friend with a 2009 rmz complains of the same thing. mabye its a suzuki thing??
Posted 02 May 2012 - 03:13 AM
check ALL the mounts / bolts ... yes all of them
make sure the chain is adjusted correctly , having wheels balanced helps .
you can fit pillow top grips and try Fasstco anti vibration inserts , i use them in my CRF
