Searching for WFO
6 replies to this topic
  • Boomer
Posted August 19, 2001 - 03:49 AM
WFO - ticking at left side of engine!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • wfo257
Posted August 19, 2001 - 08:44 AM
It is actually louder on the clutch side.
Chris
  • Boomer
Posted August 20, 2001 - 12:30 AM
WFO - I hear you. But don't be fooled - a noise within seemingly can be localized, but actually resonating from elsewhere. What??????
All I'm saying is that the noise can possibly be transfering across a shaft or like. Mine is very loud on the sprocket side, but I haven't had the engine apart to check it out yet. This may be a case where we have a similar mechanical situation, but with a different shifter fork or other component.
Please - keep us apprised on what you find.
BTW - where are you located? - I'm near Cincy.
Boomer
  • timmorg
Posted August 20, 2001 - 05:56 AM
Hey all! I just had to chime in that my engine is making the same noise-seemingly on the sprocket side of things. I broke my rear hub and I think it damaged one of my gears. Right now the engine is out and in a shop so hopefully when they replace the damaged gear it will fix the ticking sound. I noticed also that the sound went away when the bike was under load like being in gear. Im interested to see what comes of this.
:) Joe
  • Scott_F
Posted August 20, 2001 - 09:51 PM
Guys, be sure to check your counter balance gear key. Do a search for CB gear.
  • Shawbridge Husky
Posted August 20, 2001 - 11:37 AM
Mine was piston / ring slap. Maybe check out your top end?
  • wfo257
Posted August 21, 2001 - 05:32 PM
When I split the cases I put new rings on the piston and I also changed the CB gear but I guess I will check out the balancer gear key.
  • Hot  47 replies
  • Hot  36 replies
  • On January 15, 2017
  • Hot  30 replies
