CDI and Yamalink from 2009 on 2003?
4 replies to this topic
  • tobias3
Posted March 02, 2012 - 10:56 AM
Wondering if any one knows if a 2009 CDI will work in my 2003? How about a 2009 Yamalink. This is used for lowering the front suspension. Cant tell by looking on manufactures page if the diffent yars are interchangable.
  • 2grimjim
Posted March 02, 2012 - 11:19 AM
Yes, the '09 CDI should work on the '03. You won't see any performance gain though. You will probably see a drop in performance from the different timing map.
Do you mean lowering the rear suspension? I'm not aware of any 'link' in the front suspension, unless someone put a front end from a 1972 DKW on your bike.
Edited by 2grimjim, March 02, 2012 - 11:20 AM.
  • YamaLink
Posted March 02, 2012 - 02:16 PM
Was going to email you in reply to the message left, but since we're all here.... the 09 YamaLink will not fit the 03.
  • 2grimjim
Posted March 02, 2012 - 03:38 PM
If you want to lower your bike, the easiest and cheapest way is to use spacers in the damper cartridge in the fork and shock and run a shortened set of fork springs. This will lower both ends and cost about half of what a link will cost.
  • tobias3
Posted March 02, 2012 - 06:05 PM
Thanks for the input , and yes the link was to lower the rear. I will definately look in to your plan with the cardtridges. Thanks
